can u run a boost controller and bleed valve in series
Old Nov 15, 2011 | 11:13 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default can u run a boost controller and bleed valve in series
ie run the bleed off pipe off the boost controller through the bleed valve so i cant go over the set amout of boost the car was set up for
cheers(soz if im been stupid it late lol)
Old Nov 15, 2011 | 11:31 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
I dont get what that will achieve. the purpose of a boost controller is to bleed off measured amounts of boost so that the actuator works at whatever boost you want.
a bleed valve does the same except its a mechanical valve.
running both in series is likely to make you EXCEED your set up boost. Think about it, you now have introduced 2 holes in the pipe leading to the actuator, so more air is bled off before the actuator "sees" enough boost to work.
Old Nov 15, 2011 | 11:41 PM
Rsmat's Avatar
Rsmat
Either have one or the other.
Old Nov 16, 2011 | 08:31 AM
pee vee's Avatar
pee vee
Thats having 2 boost controllers, essentially.. No real need, just set the electronic one up and it should be alright!
Old Nov 16, 2011 | 12:31 PM
opposite lock's Avatar
opposite lock
Cant comment on the above but someone mentioned your spec the other day boy that is huge power and torque for T3 . NMS setup?
Old Nov 16, 2011 | 01:56 PM
ASHCOSSIE's Avatar
ASHCOSSIE
na turbo systems chip ment for a t34 mate, greens, group a k&n , full exhaust system, 3 bar, and soon to fit a front mount running standard 4x4 cooler at min, and cr turbos st3 t3
gchristophi
Aug 31, 2015 10:36 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Red_bull
Aug 25, 2015 06:27 PM
jay030787
Aug 17, 2015 06:16 PM
Escortdriver1
Jul 31, 2015 02:36 PM
