4 or 5 bar maps sensors, where from and how much?
2Evos & 1 Escort Van :-)
As title, anyone got any suggestions where I can get one from and how much?
Was really getting to enjoy the 2.5 bar mid range spike my GT35 was running on the Evo, so would like to run that more often knowing the car was well mapped to suit that higher boost. Currently run the standard Evo 9 3 bar map sensor, so anything over 2 bar it's not got a clue
I've got a hardly used one from Reyland with the alloy block that they supply from my old setup I'd sell. I'm only down the road ish too
The 5 bar one
The 5 bar one
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Si - for what it's worth - depending on your ECU and mapper - why not look into the Bosch 3.5 bar TMAP sensors?
They need two holes drilling into the plenum - one for the O-ring to seal in and one for a bolt to secure it. Acts as a MAP sensor for 2.5 bar of boost and an air temp sensor and they're fairly small - not much bigger than a normal YB ACT sensor.
Saves worrying about vacuum piping splitting etc and the sensors with a plug kit etc. are about £75. Same price as a YB 3 bar!
I reckon so looking at Richie's post!
Not a bad price, if I can get my standard ECU to work with it, thanks Tev / Richie
Thanks Will, liking the idea of simple install
MK - Saw that block on your build thread I think, you're very clever being able to knock stuff like that up
How much was the Bosch from Phillis? PM if you want, or just give me a ball park to aim at please
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
