2001 Mondeo mk3 heater problems ?
Hi my 2001 tddi Mondeo is only blowing out warm air and the functions that let you change direction of blow ain't working, any ideas? The cars a lx and ain't hot climate control it's just a basic Mondeo thanks
is it knobs or buttons?
www.fordtalk.com will list whats wrong somewhere along the line, but the site became a bit too complicated for me so i couldn't help you with finding out where to start, possibly the wiki link
The Focus suffers from the same issue as well, however the fact the OP says he can feel air shows the motor not to be a problem
I would look at the cables, I should think both of them are broken...
Martin
Martin
The seal behind this lets water thought silicon grease it and in the motor there a resistor normaly mucks up because of this change it its were the plug connects to the motor job done !
If you don't water gets into the motor and siezes it! The resistor packs are a common failure, again water ingress with the fan can cause this,as you say!
Martin
