2nd nick
Old Nov 13, 2011 | 07:37 PM
clyde 1800's Avatar
clyde 1800
Default 2nd nick
im having trouble wiring my fuel pump i have everything wired and in place apart from the wire for the ignition
its currently connected to a yellow wire which is the first turn of the key
i dont like this i want it to be the second turn on the key (2nd nick)
just basically wanting to know where to find this wire so i can tap into it?
the relay is positioned down behind where the glovebox will be
any help much appreciated
Old Nov 13, 2011 | 07:49 PM
martysmartie's Avatar
martysmartie
Yellow is the radio live.
I imagine the original looms have a take off specifically for the fuel pump relay, ECU relay etc, but having never needed to investigate that part I woulden't know for sure.
Martin
Old Nov 13, 2011 | 08:06 PM
dug112y's Avatar
dug112y
passionford pro
why are you rewiring it? it needs to be through a relay buddy.
the wire your looking for is next to the yellow one on the ignition switch.
Old Nov 13, 2011 | 08:24 PM
clyde 1800's Avatar
clyde 1800
this is from the relay i put in
you see the car originally had a manual fuel pump on the side of the block and i need an electric one
would you know possibly what colour this wire is? and where does it go?
does it go the the fuel pump?
Old Nov 13, 2011 | 08:28 PM
mk1turboestate's Avatar
mk1turboestate
is it a black wire with a yellow stripe? it is on alot of old fords,
dont forget to wire a cut off switch into the relay incase you have a bump
Old Nov 13, 2011 | 08:32 PM
dug112y's Avatar
dug112y
passionford pro
it will go to the fusebox and supply a good few of the circuits/relays in your car.
what relay have you fitted and hows it wired?
the wire should be black /yellow and you will use it to switch the relay on.
Old Nov 13, 2011 | 08:34 PM
mk1turboestate
make sure it is fused aswell
Old Nov 13, 2011 | 08:36 PM
clyde 1800's Avatar
clyde 1800
thankyou for the help people just really the colour i need and im defo not putting in a cut off
theyre an absolute curse lol
i have the relay connected up like this
ine wire to battery other to pump one to shell for earth and this one is as of yet to be connected this will turn my relay on
Old Nov 13, 2011 | 09:45 PM
martysmartie
The wire mentioned is the main ignition circuit feed, you can pick a feed up from most things as the relay only draws minimal current, I would not take it straight off the back of the ignition switch though personally!
Trouble is doing it your way the pump will run all the time (Where the ignition switch is closed that is), not a major problem but originally they are controlled by the ECU.
I had a theory but you can't use that where the relay is permantly ground.
In any case as said though any live feed should be protected by a fuse, preferably as close to the power source as possible.
Martin
Old Nov 13, 2011 | 10:02 PM
clyde 1800's Avatar
clyde 1800
i havent a fuse but will get one in tomorrow
if i was to rewire the relay where should i take it from?
Old Nov 14, 2011 | 12:25 PM
martysmartie
In most cases the pump is rewired with a direct feed from the battery, and the OE relay is used as a "Trigger" for this relay but this is kinda irrelevant in your case as your pump isn't under ECU control, don't forget to use a good grounding location for the pump, some even rewire back to the battery!
Martin
dojj
Sep 29, 2015 10:32 PM
simonmcf
Sep 22, 2015 08:40 AM
23
Sep 12, 2015 12:56 PM
