MK6 Ford Fiesta Problems
Old Nov 12, 2011 | 12:09 PM
Dan_L's Avatar
Dan_L
Default MK6 Ford Fiesta Problems
Hi,
My girlfriends MK6 Fiesta Zetec has a couple of problems.
The idle speed seens a but high, instead of being just under 1000, when warm it sits at about 1500. Is there anyway to adjust it?
The other problem is the steering seems heavier when turning to the left, this is only noticeable when she turns the wheel when the cars is pretty much stationary, like when like is parking or just settings off. Turning right is completely fine.
Any ideas?
Cheers,
Dan
Old Nov 12, 2011 | 12:11 PM
12340987's Avatar
12340987
Throttle body needs cleaning, funny thats what ive been doing today and the first two posts ive read on here are about idling issues, must be the weather.
You need to clean the butterfly flap inside the throttle body, failing that its the idle control valve or throttle position sensor, use neat clean fuel or carb cleaner to do so, i recommend finding and pulling the engine management fuse out after or disconnecting the battery for a while to reset the ECU too
Old Nov 14, 2011 | 11:52 AM
Dan_L's Avatar
Dan_L
Hi,
Thanks for the reply, I'll give that a go.
Any ideas on the power sterring issue?
Thanks,
Dan
Old Nov 14, 2011 | 12:00 PM
12340987's Avatar
12340987
Could be anything related to the steering and suspension mate, top mount on the shock absorber, wishbone bushes, track rod or rod end, or even the rack, does it knock or make any noises?
Billy_RS
16
Oct 11, 2025 09:41 PM
Botts
Aug 13, 2015 04:16 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
