Play in your Cosworth Distributor Shaft? New Product comming soon!
Old Nov 11, 2011 | 12:46 PM
James @ M Developments.'s Avatar
Default Play in your Cosworth Distributor Shaft? New Product comming soon!
Im just finishing off our new Distributor overhaul kits, be available on the webshop soon!
To rid of the play in the dizzy units which cause all manner of phase sensor issues.
New oil lite Bushing, O ring, and roll pin, plus full instructions of how to overhaul the unit.
Only takes about 20 mins to do. I think pretty much every dizzy i see has too much play in them!
Old Nov 11, 2011 | 02:19 PM
Do you not touch the timing in anyway when doing these.How much will they be.
Old Nov 11, 2011 | 02:24 PM
You just need to time it up and remove the dizzy, then make sure the phase is aligned correctly when it all goes back together.
Will be posted out for under Ł20.00, price is not set yet.
When the bushing in the dizzy has to much play the phase gap changes with revs! and can flag all sorts of weird running issues, and even knock the phase sensor out
Old Nov 11, 2011 | 02:30 PM
Rax's Avatar
Rax
This should save some people a headache and probably a must for most cosworth owners imo
Old Nov 11, 2011 | 02:34 PM
I hope so, most i see have a fair bit of play in them.
Old Nov 11, 2011 | 03:37 PM
paul16v's Avatar
paul16v
Monte 087
Sounds like a good idea. I used to machine oil lite, strange material.
Old Nov 11, 2011 | 04:07 PM
Sounds easy. 20quif is cheap too.
Old Nov 11, 2011 | 05:27 PM
Mr RS500's Avatar
Mr RS500
A good product as i have never seen a cossie dizzy that hasnt got play
Old Nov 11, 2011 | 05:41 PM
BRAMMER's Avatar
BRAMMER
Just what I've been waiting for for mine
Old Nov 11, 2011 | 05:51 PM
Icurus's Avatar
Icurus
What's a Distributor?
Old Oct 18, 2017 | 07:31 PM
Adam-M's Avatar
Adam-M
Old thread I know
Anyone know where you can get the parts to refurb the cosworth distributor? I've emailed stu at MSD but no luck.
Old Oct 18, 2017 | 07:33 PM
Caddyshack's Avatar
Caddyshack
Originally Posted by Adam-M
Old thread I know
Do you still use the dizzy or just the hall sensor? I am swapping to sensor on the cam and will remove the dizzy.
Old Oct 18, 2017 | 07:38 PM
Adam-M's Avatar
Adam-M
I'm going coil on plug mate but rather than fit the cam sensor on the cam cover I'm going to keep the phase sensor on the dizzy and remove the cap. Just want to freshing it up while it's all in bits.
Old Oct 18, 2017 | 07:58 PM
Caddyshack's Avatar
Caddyshack
Makes sense to use this kit then I think.
Old Oct 18, 2017 | 08:14 PM
james kiely's Avatar
james kiely
might be worth giving james a shout at auto dynamix ,or loomer on here
Old Oct 18, 2017 | 09:04 PM
Adam-M's Avatar
Adam-M
Just sent him a pm mate cheers
Old Oct 23, 2017 | 08:31 AM
R4N SS's Avatar
R4N SS
better off with coil packs anyway
Old Oct 23, 2017 | 09:14 AM
Adam-M's Avatar
Adam-M
Still need a phase or cam sensor
Old Oct 23, 2017 | 03:00 PM
R4N SS's Avatar
R4N SS
but at least it gets rid of the old dizzy and arm
Old Oct 23, 2017 | 07:50 PM
Adam-M's Avatar
Adam-M
I can't I've just bought a lovely anodised dizzy cap blank
I'll have a think about it like you say would be good to get rid of all the old shite
Aug 14, 2015 07:29 AM
Sjieter
Aug 5, 2015 09:47 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
