Ford Sierra 2.0i pinto ECU difference (N4B and N4A)
Hello!
I have ford sierra with 2.0i CAT pinto engine (N4B I suppose?), problem is with lambda sensor it is dying or already dead. Also CAT is cutted out a long time ago, so there is no need for lambda sensor anymore, so my question is - is there possible to fit ECU from earlyer 2.0i pinto without CAT (N4A it was, I think). I know, that it isn't direct fit, but what i wan't to know is that is there needed any other wiring to N4A ecu? Or i just can change pins in ecu plugs and plug older ecu in? Also maybe someone have pinouts/wiring diagrams for 2.0i pinto CAT and for usual 2.0i pinto?
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Aug 9, 2015 07:03 PM
