new rear hub bearing really stiff?
Ive just installed a new set of rear hub bearing to my sapphire, but there really stiff when trying to turn the hub by hand. ive installed them correctly and tightened the hub nut to 250 nm as it says in the manual. any ideas on why they are so stiff.
many thanks carl
many thanks carl
is this when its all built up on the car or with the rear axle/shafts not all bolted up?
dont forget it has an LSD in the arse end and WILL be stiff to turn
unbolt the driveshaft at the hub , not outer CV and see what its like then
no mate its on the garage floor. i got told by a mechanic to loosen them off abit. what do you think.
here the pic of it at the mo
https://passionford.com/forum/album....ictureid=22140
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
