Fan only works on setting 4 ?
Hi, I am new here and hope someone can help, I have a 2001 ford focus 1.6 and the fan heater has totally stopped working except on setting 4, this has only just happened and as winter is setting in is a right nuisance.
Is it at all possible to fix it myself with a bit of guidance or should it go to the garage and if so does anyone have any idea what to expect cost wise.
Also I might as well ask in the same post...the air bag light keeps coming on, it stays on for a while goes off but then comes back on again ?
Thanks in advance for any help.
I would guess that it could be the heater resister pack gone which would be why it only works on the highest speed.
Here you go
http://www.ebay.co.uk/itm/BRAND-NEW-...item3f0a312847
Here you go
I have the same problem, on an 02 plate Focus 1.6 LX, but I cannot locate the resister at all, it just isn't there, or it's I've over looked it because its in a different place? There is no blue resister pack next to the heating unit. I would be grateful for any help on this matter? Many thanks
Zoggon
Aug 10, 2015 10:39 AM
