my xr3i efi has a pretty bad engine judder when driving
Old Oct 29, 2011 | 04:48 PM
willtorrance's Avatar
willtorrance
Default my xr3i efi has a pretty bad engine judder when driving
hi people can use help me. my xr3i
(efi) has got an engine judder pretty bad when driving, its fine when ticking over or if u rev it its fine jst when driving, what could this be? the engine has just been rebuilt too......
Old Oct 29, 2011 | 06:50 PM
tommytwotanks's Avatar
tommytwotanks
have you done any tests to see if you can norrow it down, like reving it until it misfires and then taking a plug lead off, then swaping a plug to see if the misfire moves, you could do the same with the injectors
or just put the car on a diagnostic machine at a local garage, might cost Ł40 depending on where you are
Old Oct 29, 2011 | 07:40 PM
willtorrance
Originally Posted by tommytwotanks;[URL="tel:5680137"
5680137[/URL]]have you done any tests to see if you can norrow it down, like reving it until it misfires and then taking a plug lead off, then swaping a plug to see if the misfire moves, you could do the same with the injectors
hi, Ive not long had the engine rebuild new plugs and leads last week new clutch and gearbox. do you think it could have anything to do with the fuel relay or fuel pump? or anything else? any info is much appreciated thank you
Old Oct 29, 2011 | 07:44 PM
willtorrance
hi, Ive not long had the engine rebuild plugs n leads were done last week. gearbox and clutch recently fitted. its kinda got a flatspot too and juddering. its jst whern its driven and on tick over its ok and ok when you rev it, do you think it could be down to the fuel relay or fuel pump? any info you can give me is much appreciated thank you
Old Oct 29, 2011 | 08:57 PM
tommytwotanks
a mate of mine many years a go had a 1986 d reg xr31, the coil pack went on that, and the 1990 xr3i cab that i had the fuel pump went, cant you call out the AA or RAC to check or get a local garage to call round
do you think it could be a blocked injector
Old Oct 31, 2011 | 01:10 PM
willtorrance
im not sure mate worth a try i suppose
Old Oct 31, 2011 | 01:11 PM
willtorrance
just want it sorting asap as its sold some ppl say its the air and fuel mix. do u no how to change it?
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
Archiejay
Aug 12, 2015 12:07 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
