Tried to fill my transit up today but couldn't
Old Oct 27, 2011 | 07:39 PM
RichieST's Avatar
RichieST
Same thing happened to me the other day, they allowed max £52, so that's 3/4 of a tank then!
pani_k's Avatar
pani_k
PassionFORD Member
I'm confused if it has a cut off limit of £100 why couldn't you put more in?
Old Oct 27, 2011 | 07:40 PM
stoke7up's Avatar
stoke7up
Tony thats one expensive shell station
Old Oct 27, 2011 | 07:54 PM
timster's Avatar
timster
perhaps they know you have a poous and think you should be driving around in that instead
Old Oct 27, 2011 | 07:56 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Your paying about 10p a litre more than where I am, diesel anyway.
Old Oct 27, 2011 | 08:03 PM
scoooby slayer's Avatar
scoooby slayer
Originally Posted by Tony Mannock
I had to fill up wouldn't have made it to the next station on route
I could have gone out of my way and got it cheaper but that would have no doubt used more in fuel than i would have saved
I also had to be in manchester by a certain time then onto burnley then onto leeds glad my nottingham vsist was cancelled the traffic in leeds was horrific
blimey your putting it about abit mate lol
Old Oct 27, 2011 | 08:08 PM
anglia105e hinson's Avatar
anglia105e hinson
It's bad aint it. It cost me £112 to fill my transit up.
Old Oct 27, 2011 | 08:11 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
nothing exciting collecting radiators and heating bits mucho cheapo for my new divorce house
some wank plumber has done the usual of a cheap install and stuck the rads on the back walls not under the windows so it's turbosystems plumbing and central heating engineers this weekend
why do they get put under windows
we had all ours put on other walls (rented house on a grant with oil rads in situe)
its much better than under windows
why would you heat the window 1st? i never had understood so figure it was to save space as window walls are already wasted
as ours are they heat the room before the window but my mums has them under windows and its always fookin freezing unless you sit on the window sill to get warm
she has a gas fire at the other end of the room and you can feel the heat come across the roam when thats on
Old Oct 27, 2011 | 08:18 PM
Eagle's Avatar
Eagle
Super Moderator
filled the van up the other day .. £107 ..
Old Oct 27, 2011 | 08:34 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
bit of a funny one really, partially due to space, i.e. no book cases infront of windows, so fit a radiator, but also they act as a heat curtain, this reduces heat coming from middle of room and cooling as it meets the windows. same principal in supermarkets etc. as you enter there is a stream of heat that hits you from above the door, basically stops the temperature gradient which pulls the heat from it's source to the coldest part. image the middle of your room being warm, but the ends near windows freezing.
if your mum has problems then radiators and boiler aren't adequate for the job. bigger kit will actually save money.
back on topic, shite isn't it, sadly we are a weak nation and not capable of mounting a strong enough resistance to reduce the cost. even if we did, tax on other things would increase to compensate.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
