1.8 zvh
Old Oct 26, 2011 | 06:12 PM
pikeyrs's Avatar
pikeyrs
Default 1.8 zvh
Hi guys I'm after a bit of advice. I recently bought a escort Rs turbo 1.8 zvh.
Now the problem I've got is the rev counter does not work and the battery keeps draining. Any help will be appreciated!
thanx in advance
Old Oct 28, 2011 | 07:39 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Battery draining is one of 3 things:
Battery is knackered (get it tested, halfords even do it IIRC)
Alternator isnt charging (check with a volt meter)
Something is draining it which shouldnt be
With regards to rev counter, might just not be connected, hard to say without seeing how it is wired in, or the ecu you have might not be compatible with your clocks.
Old Oct 28, 2011 | 08:52 PM
pikeyrs's Avatar
pikeyrs
Thanks for reply chip, previous owner says rev gauge and battery draining started at the same time.
Anyway a bit of investinging today with volt meter is pointing to alternator so new one on way!
Chas
Oct 5, 2015 07:13 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
davidfordrs
Sep 21, 2015 04:23 AM
talon1
Sep 15, 2015 10:27 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
