3dr cosworth front brake upgrade advice please.
Old Oct 26, 2011 | 12:23 PM
g10ens's Avatar
g10ens
Default 3dr cosworth front brake upgrade advice please.
The front discs on my 3dr need replacing and the callipers need re-building so im thinking i might aswell upgrade them to something slightly better that will also fill out the 17" wheels.
I've been looking at these on ebay,
The hi-spec ones are second hand so not sure how much theyre actually worth and not really heard a lot of feedback about them as i dont know anyone who has them.
http://www.ebay.co.uk/itm/1606710373...84.m1423.l2649
The other set uses focus discs and re-built BMW E38 callipers with an adaptor kit.
http://www.ebay.co.uk/itm/2208077830...84.m1423.l2649
Anyone got any opinions on either of these?
The car is only for road use and i dont want to spend a fortune on top spec brakes that are un-necessary for general road driving.
I just want some that will fill out the 17" wheels and also stop the car quite well.
Old Oct 26, 2011 | 12:32 PM
Staffi's Avatar
Staffi
If you can afford it then i'd opt for the AP Brakes, yes expensive BUT awesome stopping power, best mod i did on my 3dr, especially if you're running biggish power, or plan to. Mine's only a road car but you'd be suprised how much later and how much confidence these give you
I'm sure others will have other advice too...
Old Oct 26, 2011 | 01:56 PM
phil_rs's Avatar
phil_rs
yam yammer
AP's really are worth the investment IMO. I would rather buy some second hand AP's than new hi spec or similar
Old Oct 26, 2011 | 02:52 PM
SteveB's Avatar
SteveB
For under £500.....
Focus RS Brembo 4 pot calipers £150-250
Focus RS 324mm x 28mm discs £100
Custom brackets £75
Braided lines if you've not got them on front (use 4wd Cossie 1's) £30-35
Pads £30 onwards depending on what you want
Steve
Old Oct 26, 2011 | 03:01 PM
RS500/364's Avatar
RS500/364
£500 for the first ones
i take the compbrake 4 pot kit off my RS 500 for £675 and there not to bad as done 2k on erm !
and i have me standard one to go back on !
Old Oct 26, 2011 | 03:25 PM
dojj's Avatar
dojj
Resident Wrestling Legend
http://www.ebay.co.uk/itm/160671037363?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
http://www.ebay.co.uk/itm/220807783026?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
the hispec stuff, normally they don't come with seals as they were race application stuff so that's what you've got to find out first
the second one is a nice bolt on kit so to save yourself from running around collecting all the bits, it's a winner for less than £500
Old Oct 26, 2011 | 03:27 PM
Char1ie's Avatar
Char1ie
I had big HiSpec calipers and they looked the part but didn't perform the part. Crap quality, fluid loss from the calipers that probably warped with heat from heavy use. I would stick to the big names - AP, Brembo for example.
Charlie
Old Oct 26, 2011 | 04:20 PM
sierrafun's Avatar
sierrafun
Charlie
mate i didnt know that is was big problems with hi-spec brakes .i thought are fine .anyway i use six pots brakes ap racing .they are fine
Old Oct 26, 2011 | 04:35 PM
daz1968's Avatar
daz1968
I think the set with BMW brembos and focus discs is very good for money, brembos are very good quality and as they use focus discs then will be easy to change in the future,
Old Oct 26, 2011 | 04:54 PM
sierrafun's Avatar
sierrafun
focus dics can fit to the 2wd cossie i think not 4x4 cosworth
Old Oct 26, 2011 | 05:38 PM
coswurv's Avatar
coswurv
Here's my 2wd saph with Evo 9 front brembos, rs discs and some alloy brackets, can do it for around £300,
comparison
Let me know if you want some brackets making.
Old Oct 26, 2011 | 07:38 PM
daz1968's Avatar
daz1968
looks very good, do most 17 inch wheels clear the brembo evo 9 calipers or do you need to choose carefully, My car is currently on stock wheels and am considering larger wheels to enable brakes to be upgraded but was hoping I could fit some 17 inch bbs split rim replicas, But due to size of those evo calipers not sure if it would clear.
Old Oct 27, 2011 | 10:31 AM
R4N SS's Avatar
R4N SS
ive ordered the brackets from that ebay listing that uses the E38 brembo calipers - better fooking fit my focus rs brembo calipers
Old Dec 26, 2014 | 05:38 PM
TOMMY_TURBO's Avatar
TOMMY_TURBO
Coswurv Do u still make your brackets and how much are they
Old Dec 26, 2014 | 06:08 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I had a cheap kit a compbrake one yes they worked and were a lot better than standard but would fade out once hot. My ap's are far better there made from better materials so disperse heat better.
Old Dec 30, 2014 | 03:35 PM
R4N SS's Avatar
R4N SS
got Focus RS Brembo calipers and discs on my saf once i got proper brackets ordered
Old Dec 30, 2014 | 05:36 PM
TOMMY_TURBO
Were did you got the brackets from mate also u got any pics
Old Dec 30, 2014 | 05:48 PM
Colin N's Avatar
Colin N
Colin N
Reading this I must be the only person really happy with my Hi Spec 335 Monster brakes, never had any probs and they work really well
Only pic I can find but would defiantly buy them again
Old Dec 30, 2014 | 06:48 PM
costina's Avatar
costina
Live long and prosper!!
Focus brembos fit at a funny angle and look crap imo.
If those brackets come from caprisport then good luck.
Old Dec 30, 2014 | 06:54 PM
costina's Avatar
costina
Think they are different mate. and as said in my above post
just looked and the bolt spacing looks different please check.
Regards
Paul
Old Jan 2, 2015 | 11:53 AM
R4N SS's Avatar
R4N SS
got my spacers off someone on here - cant remember their username now tho.
Might have their number on my old iphone but i broke the screen last week
Old Jan 2, 2015 | 12:37 PM
costina's Avatar
costina
It will prob be ok then mate
Old Jan 2, 2015 | 03:12 PM
2wd's Avatar
2wd
Hi . why not try this ... : COSWORTH 2WD PRO-RACE 7 4 POT (335x32MM) .. from Compbrake ? Been running this kit for years now .. both on road and several track days and its been working super from day one !
Old Jan 2, 2015 | 03:20 PM
Caddyshack's Avatar
Caddyshack
Also look at the mt Motorsport stuff or Reyland.
Biggred do seal kits for the std caliber and they are a doddle to rebuild. I think you would be amazed what a rebuild will do, add some decent pads and then a bigger disc kit and a brake fluid change.
Old Jan 2, 2015 | 03:50 PM
R4N SS's Avatar
R4N SS
They are fine on my car now - the guy i bought my brakes off supplied me with a set of brakcets but they were so shite after fitting them they collapsed dropping the caliper into my freshly refurbed wheels - so had to do some research and buy proper brackets. Now they work well when the car works lol
Old Jan 2, 2015 | 05:16 PM
costina's Avatar
costina
< I Used to run that kit but in the 350mm form and as their brembos are from Porker and audi pads are a good price. I still have the kit and machined up some brackets to fit the cortina
Old Jan 2, 2015 | 05:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Amen Pete , I wish I'd fitted my 6 pot AP's from the start rather than wasting money on Hi-spec. Here's mine......
Old Jan 2, 2015 | 07:33 PM
2wd's Avatar
2wd
Old Jan 5, 2015 | 04:15 PM
R4N SS's Avatar
R4N SS
you can see my brakes fitted in my saf resto thread
Old Jan 5, 2015 | 05:41 PM
Caddyshack's Avatar
Caddyshack
Great pic....almost rude!
original
Apr 28, 2026 05:20 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Aug 10, 2015 12:08 PM
knight19770
Aug 4, 2015 12:36 PM
