Whose changed 4x4 front diff to LSD
Old Oct 25, 2011 | 11:44 PM
Rob Virgo's Avatar
Rob Virgo
Thumbs up Whose changed 4x4 front diff to LSD
Whos changed
What to
Why change
What difference to drive
Rob v
Old Oct 26, 2011 | 06:45 AM
DangerousBryan's Avatar
DangerousBryan
can only guess but it will understeer a lot more i think,make the steering heavier as well. try driving a subaru justy with the 4wd button pressed.
Old Oct 26, 2011 | 08:45 AM
Blades Rally Team's Avatar
Blades Rally Team
Default LSD Front Diff
Been using an ATB front Diff in my Rally Car for Years the big benefit is that I find it turns in better and pulls out of corners quicker but I use a very aggressive set-up on the front end
Old Oct 26, 2011 | 02:44 PM
Rob Virgo's Avatar
Rob Virgo
Surely could dial out understeer with tyre and spring changes
Not really a real 4x4 with an open diff
Old Oct 26, 2011 | 03:27 PM
dojj's Avatar
dojj
Resident Wrestling Legend
understeer city i would have thought
Old Oct 26, 2011 | 05:44 PM
Paul_RS's Avatar
Paul_RS
I have an ATB on mine, haven't noticed much difference to be honest. I does seem to pull out of corners a bit better.
Don't know where people are getting this understeer theory from It also makes no difference to the steering, a plated diff would, but not an ATB.
I changed as i wanted a stronger diff (mine has a thickwall casing)
Old Oct 26, 2011 | 10:40 PM
Rob Virgo's Avatar
Rob Virgo
I guess you havnt tracked it paul, I had a lot of wheelspin on a trackday last year ( drivers front I think) , really ruined the pickup out of corners , thought of an atb
Must ask the micheal bird
Old Oct 27, 2011 | 07:47 AM
Rob Virgo's Avatar
Rob Virgo
By tracked I mean on track obviously ....lol
Old Oct 27, 2011 | 08:22 AM
Porkie's Avatar
Porkie
I ran an ATB in front of Sierra for a while. It had horrific understeer.... few people suggested it maybe have been the diff. So we went back to an standard one.
Still understeered!
If only I knew now what I knew then about car set up and how important it is!
Old Oct 27, 2011 | 01:59 PM
Jim S's Avatar
Jim S
From: Yarm (Teesside) previously from Fyvie (Aberdeenshire)
Most 4x4's are not proper 4x4, some even have an open rear diff as well
Old Oct 27, 2011 | 03:11 PM
Rob Virgo's Avatar
Rob Virgo
Tons
Ads, still no clearer on if it would be better really, who has over 400 Jp and a std diff, is it wheelspin city on power application when front right is unloaded....
Old Oct 27, 2011 | 06:17 PM
dojj's Avatar
dojj
on the sierra the centre diff in the box is a viscous as well as the rear, the front is open because if you have spinning rears the power goes to the front under load, when you are going round corners the car is designed to oversteer as you have more torque going to the rears and the centre diff is the weakest link
you would be better to swap the centre diff for a higher rated torque rating before shelling out on a lsd for the front as this is the weak point
from what i can remember, cts did various stages of uprated centre diffs
Old Oct 27, 2011 | 07:28 PM
graham c's Avatar
graham c
am interested in this too
Old Oct 28, 2011 | 10:24 AM
Blades Rally Team
Default Front ATB Diff
I run an ATB front Diff and a Powerlocker (American) Rear Diff 8" (Specially made by Glebe Engineering) and a Centre Viscous Diff the front end is set to FORD's Tarmac Standard set-up 3.5 degree neg Camber / 3 degree Caster / and 2mm toe-in this seem to work very well and I do not suffer any understeer (this is very aggressive on the tyres through)
Chas
Sep 21, 2015 08:57 PM
Anutternutter
Aug 21, 2015 06:07 PM
C2 MAK
Aug 20, 2015 09:46 PM
st220kyle
16
Aug 14, 2015 06:13 AM
Old ford
Jul 31, 2015 06:50 AM
