Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Ford Focus 1.4 zetec se
Old Oct 23, 2011 | 06:46 PM
alastair007's Avatar
alastair007
Default Ford Focus 1.4 zetec se
Hi All
i am in need of some advice.
when you dip the clutch to change gear the revs jump up to 3000 rpm
the same happens when you are coming to a stop at lights ect.
if you depress the clutch and coast for a short while the revs jump up and down between 800 and 3000 rpm.
when you come to a stop the revs jump up to 3000 then drop to 2000 then back to idle @ 1200 ish.
took it into a garage to did a diagnostic said it MAY be the speed sensor, so we had that job done, but the problem still persists.
would be gratefull for any advice/help
Regards
Alastair
Old Oct 23, 2011 | 06:49 PM
Bailes1992's Avatar
Bailes1992
Sticky idle speed control valve, mine does this. It's pretty annoying at times.
Old Oct 23, 2011 | 07:03 PM
alastair007
Thanks for your reply, is it a simple part to clean or do you just replace it?
Regards
Al
Old Oct 23, 2011 | 07:11 PM
trev1964's Avatar
trev1964
About Ł35 for a new one I think.
I would stick a new one on if it were me.
Old Oct 23, 2011 | 07:14 PM
alastair007
Thanks, i will do that
Regards
Al
Old Oct 23, 2011 | 07:50 PM
martysmartie's Avatar
martysmartie
You can clean them using brake fluid/petrol etc, it's at least worth a try before spending out on a new one!
Martin
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
taylora1409
Aug 12, 2015 12:06 PM
