cossie rear wishbones, 2wd, 4wd same??
Old Oct 22, 2011 | 06:38 PM
forevaford's Avatar
forevaford
Default cossie rear wishbones, 2wd, 4wd same??
are saph cossie rear wishbones the same? i know the hubs and shafts are different.??
Old Oct 22, 2011 | 07:14 PM
martysmartie's Avatar
martysmartie
No I think the trailing arms on 2WD models, i.e. 3DR and Saph are different due to the lower ride height. 4x4 I believe may be the same.
I think there are actually two types and the one I mention above alters the track as well.
Martin
Old Oct 22, 2011 | 07:20 PM
forevaford's Avatar
forevaford
4x4 are the same as what?, iv got complete rear ends off 2wd and 4wn, im trying to make the best of the 2, so i want the 4wd rear wishbones/trailing arms in the 2wd beam. its for a 2wd saph. but if there different then i cant use them.
thanks for your reply
Old Oct 22, 2011 | 07:26 PM
fraser9764's Avatar
fraser9764
I believe there is a difference, but not to do with ride height, best to give 'a rs licker' a PM on here.
Old Oct 22, 2011 | 07:30 PM
martysmartie
4x4 Cosworth was the same rear end as lesser models, I am sure I am right in saying the trailing arms were as well, in which case you can't use the 4x4 arms in the 2WD car as these were unique to suit the lower ride height so far as I know.
Incidentally if you diden't know the 2WD beam is also unique and different from the rest of the range!
Martin
Old Oct 22, 2011 | 07:31 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Saff 2wd, Saff4x4 and Escos trailing arms are the same. Only odd ones are 3door ones which have anti roll bar pick up points in a different place.
martysmartie
For the ride height indirectly, I am sure it alters the camber/track as I say to suit the lower ride height.
Martin
Old Oct 22, 2011 | 07:33 PM
martysmartie
This rings a bell now you mention it, hasen't it got something to do with the mounting point being 'inboard'?
Martin
Old Oct 22, 2011 | 07:49 PM
robrs2's Avatar
robrs2
Do get the xr4x4 ones mixed up either. I fitted a beam that turned out to have a cosworth arm one side and an xr the other. Camber and toe both different
Old Oct 23, 2011 | 09:41 AM
forevaford's Avatar
forevaford
umm, thanks for the replys, quiet a mixture of answers tho, last thing i want is to incriminate the handling
Old Oct 24, 2011 | 12:07 PM
opposite lock's Avatar
opposite lock
Excellent info there
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Ridgey
Aug 30, 2015 08:37 AM
RsS2daz
Aug 14, 2015 05:26 AM
lockie
Jul 31, 2015 10:03 PM
