Cossie regulator, after the injectors??
Old Oct 22, 2011 | 04:48 PM
baz walton's Avatar
baz walton
Rock Out!!
Default Cossie regulator, after the injectors??
Hi troops,
As stated in the other thread I have just posted about the cossie fuel problems.
I have discovered from the confused faces of each mechanic at the unit where my car is, that the regulator at the end of the rail isnt 'normal' practice.
On other cars, I was informed, the regulator is before the rail/injectors and uses a relay to open and close the reg as required.
Mine (rally cossie) has the pumps running fuel straight to the rear of the rail and then the reg at the front end, after the injectors, opens when the pressure rises past a certain point and returns the unsued fuel to the tank.
Firstly: Is this the correct way?
Secondly: what pressures are involved here?
I think I remember that the reg is set to open at 3 bar?
Also what pressure is the fuel pump/s putting out (mine are bosch 044 )
I was informed that the return to the tank should really just be spitting as the reg opens, but mine opens within seconds and stays that way with a heavy flow constantly returning to the tank.
Again, Is this correct?
Old Oct 22, 2011 | 05:04 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
as the above posts state. reg sits at end of rail and then bleeds off the un necessary fuel back to tank to relieve pressure. otherwise you'd have a restriction before the injectors and would experience pressure drops before the injectors and not after.
baz walton's Avatar
baz walton
Rock Out!!
Cheers Tony, I have realised that the problem on the other post is elecrical related, this was just me wondering. (i was fairly certain the set up was ok as I have run like that for over ten years) , it was just when 3 different people looked strangely at it I thought I'd check.
Old Oct 22, 2011 | 05:10 PM
baz walton's Avatar
baz walton
Rock Out!!
You knew what I meant.
I 'thought' it was right, but had never had reason to question it.
Old Oct 27, 2011 | 09:01 PM
stevieturbo's Avatar
stevieturbo
C**t
Originally Posted by baz walton
Hi troops,
Whoever informed you of all this is a total idiot. And you need to run away from those "mechanics" very very quickly !
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
