Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
03 Fiesta Ghia remote boot lock problem
Old Oct 21, 2011 | 01:43 PM
Stormyk's Avatar
Stormyk
Default 03 Fiesta Ghia remote boot lock problem
Hi
My wife's remote book lock (operated by the switch on the dashboard) has stopped working.
I took the boot panel off and the actuator does appear to move, but not enough to open the lock.
I took the actuator off and put 12v across it and it seems operate satisfactorily ie pulls the rack (which in turn pulls the boot lock cable) in fine, although it wasn't under any load (ie pulling anything)
However when I operate it off the dashboard switch, it doesn't seem to have enough oomph to open it and only moves a small distance.
Is it likely to be a faulty actuator or could there be a relay problem? Because the actuator does actually move when you press the switch I would have thought it wasn't that.
Any advice?
Regards
Keith
Old Oct 21, 2011 | 01:58 PM
dojj's Avatar
dojj
Resident Wrestling Legend
If the switch works then it's fine and so you would need to point the finger at the actuator
Close the boot lock with the boot open and see what happens as the action should be fairly "violent"
Old Aug 8, 2013 | 10:34 AM
toys'r's's Avatar
toys'r's
Sorry to drag up an old post but did u manage to fix your problem Stormyk? I have exactly the same issue on my 07 Fiesta, actuator moves but with no real power, not enough to unlock the boot. My suspicion was the actuator needs replacing but wondered if there could be another solution (relay?)
Thanks
Old Jan 10, 2014 | 04:41 PM
itekweni's Avatar
itekweni
Hi has this problem been sorted as my partners car has now developed a similar fault and could the out come be shared with me ...thanks in advanced
JoeyBoyden
Jan 4, 2024 02:36 PM
YODI
Aug 30, 2015 01:12 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
tankybaby66
Aug 9, 2015 07:13 AM
