best place to get an ecu and mapped??
Looking for an ecu for my cosworth 2wd but has to be whit new loom and mapped. I am from belgium so if it's possible not to far in the uk?Or if someone can do an off the self chip but i think this is not possible. Engine spec is: 200 long studded block, cosworth pistons 7.6:1cr mountune L651s cams, neil roper ported head whit solid lifters, GT3542r .82 housing, 83lbs siemens injectors, hart inlet.
Mark
I've just had on of these:
http://www.syvecs.com/s6gp.php
Mapped by here:
http://h-dev.co.uk/index2.php?page=home
It drives so so well now.. Little bit more mapping needed to finish but I'm chuffed to bits with the result!
Mapped by here:
Mapped by here:
Mapped by here:
I want to go aftermarket but here in belgium is nobody who can fit and map it properly so i need to come to the uk but i am looking who i not to far in the uk.
From my place to MAD is about 5hours inc the boat so it's not so far. It's just that i don't have much time the next couple off months and i need to now if it's possible to fit and map it in one day.
If it's a brand new map I don't think so mate as u only get one chance a day at cold start mapping.
Best to speak to the tuner u want the work done from and see what they recommend
Mapped by here:
Mapped by here:
Although pretty sure they were plug n play versions.
Obviously a brand new install would really need to be up and running first before that could take place.
Whilst the UK isnt that far I guess, surely there has to be a tuner in Belgium or surrounding countries who is more than capable of getting things running ?
Adaptronic have a dealer in Netherlands, and would no doubt be more than capable
http://www.adaptronic.nl/home/adaptronic.html
Motec have a dealer in Belgium, Kempower. And again would no doubt have various options. Some of their newest ecu's are far better value than their old ones ( ie more affordable )
http://www.motec.com.au/dealers/dealerseurope/#Belgium
Dont underestimate having local support handy if you arent able to repair/tune/diagnose stuff yourself.
If i have to go to kempower it will cost me the double off what mad will ask as you pay for there name. I've had an adaptronic fitted by this guy and he melted my engine and i was not the fist one!! So i will get in contact whit MAD and see if he can help me.
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
