fuel hose question!
Old Oct 20, 2011 | 03:13 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default fuel hose question!
im in the middle of up rateing my fuel system im going -8 from the pump to the rail then from the rail back to the tank all with aeroquip fittings but the hose from the tank to the pump is larger anyone no what size hose this is please so i can order the fittings for my pump and tank
Old Oct 20, 2011 | 04:00 PM
wes's Avatar
wes
Hose to pump from tank is -10 (5/8")
Old Oct 21, 2011 | 09:50 PM
stevieturbo's Avatar
stevieturbo
C**t
-8 ? Holy fuck, how much power you intending to make ?
Even -6 will support 1000bhp.
Old Oct 21, 2011 | 10:01 PM
Ade500's Avatar
Ade500
Fixing Fords
Really? I was told more like 500 to 550hp - 6 is small I have used dash 8 as some of the fittings are smaller inside and it can't hurt to be a bit large but a bit small could end in real tears.
Old Oct 21, 2011 | 10:05 PM
Ade500's Avatar
Ade500
Fixing Fords
To OP I will look up the pipe I used, I thought it was dash 12 but I will check it.
Old Oct 21, 2011 | 10:07 PM
stevieturbo
C**t
Most LS guys in the US just use -6 from pump to rails.
I flow tested my as installed fuel system -8 feed with -6 return and it supported 486lph measured after the FPR and via the -6 return line at 60psi rail pressure
Flow would have been higher with better battery voltage.
I dont imagine too many cossies needing that sort of flow ability.
And the biggest restriction in the system will be the FPR anyway.
Plus, how big are the fittings on any fuel filter ? How big is the "rather tiny" outlet on the pump ?
Unless you have a multitude of bad bends, -6 will be more than adequate for 99% of Cossie engines.
Old Oct 21, 2011 | 10:10 PM
stevieturbo
C**t
Even an 8mm OD hardline steel line will support 500bhp ( at a push though ). That's only around 6.5mm ID
But always use a quality hose. I think some of the cheaper -6 stuff may be smaller inside than proper hose. So always check actual ID.
Defo cant hurt going too large. But it can be harder to install due to the hose size, and is obviously more expensive.
-8 is serious overkill though.
I think fuel tank outlet is 5/8 approx ? ie -10
Old Oct 21, 2011 | 10:13 PM
Ade500's Avatar
Ade500
Fixing Fords
I thought they use 2 dash 6 to the rail as it is a v8? I ditched all the small fittings and used a fuel lab reg with 2 dash 10 inlets on it and I'm only using one and a dash 8 and they say a dash 6 return in the fitting instructions.
Old Oct 21, 2011 | 10:22 PM
stevieturbo
C**t
Nobody in their right mind would use 2 lines when one is easier and works. Many people either Y block, tee, or flow through to each rail.
Engine size or configuration makes no difference to fuel flow required. If you need 100 litres of fuel to make 100bhp, then you pretty much need 100 litres of flow regardless of what is consuming the fuel.
Many regulators will come wit oversize fittings to accommodate various applications, including methanol etc which will require around double the flow of a petrol based setup.
For normal applications, thats why they offer them with -6 ports all round.
Old Oct 21, 2011 | 10:39 PM
Ade500's Avatar
Ade500
Fixing Fords
Sorry it has 2 inlets in the reg at dash 10 so one from each rail on a v8 not from the tank but as long as it can't hurt I'm happy with dash 8. They seem to all spec a larger delivery hose, say dash 10 or 8 and a smaller return an 8 or a 6 to allow room for fuel used. Do you know is there a calc for fuel to hp ratings? Cheers
Old Oct 21, 2011 | 11:06 PM
stevieturbo
C**t
I know, but unless it was well into four figures power wise on methanol, -10 at the reg is massive overkill also.
Especially if there is a single -6 return lol
very approximately, a boosted engine will want around 560cc/min of fuel per 100bhp.
Old Oct 21, 2011 | 11:20 PM
Ade500's Avatar
Ade500
Fixing Fords
That's over 3 litres a min at 550hp ouch lol Mines all done dash 8 flow and return I think a dash 6 return would be fine but the feed was a little to close with a safety margin so I went dash 8. As I replaced it all the cost wasn't much in it 6 to 8. Cheers
Old Oct 24, 2011 | 01:18 PM
ajamesc's Avatar
ajamesc
Missed a few posts here as ive been away all weekend. I put -8 but meant -6 which im told is good for up to 600bhp!
Old Oct 24, 2011 | 07:42 PM
stevieturbo
C**t
And Ive already stated -6 will easily support 1000bhp.
Old Oct 24, 2011 | 08:53 PM
ajamesc's Avatar
ajamesc
id rather take the advise of the tunner i use mate
Old Oct 24, 2011 | 09:13 PM
stevieturbo
C**t
You may do.
I'd sooner believe fact and those who have actually done it.
But he is of course correct in saying -6 can support 600bhp. But it will far exceed it with ease too. He's maybe just never got over 600bhp
Old Oct 24, 2011 | 09:28 PM
ajamesc's Avatar
ajamesc
You may do.
yeah hes gone way over 600
JK12
33
Apr 26, 2021 12:09 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
simonmcf
Sep 22, 2015 08:40 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
hopper350
Sep 4, 2015 12:53 AM
