What amp fuse to use for a fuel pump?
Has a large member
Hi Guys
Just re-wired the fuel pump on my tina and i want to run an in-line fuse holder and fuse. wondering what amp is correct for this?
Its a ZX9r kawasaki pump
Has a large member
Been searching but couldnt find any info.. But it seems the average bike fuel pump fuse is 10amp.
was just hoping there was a general fuse recommendation for a power to fuel pump wire.
The fuse is more to protect the wiring itself than the actual pump. So the fuse should always be the lowest that will safely power the device without blowing.
JK12
33
Apr 26, 2021 12:09 PM
