t34 help
Old Oct 8, 2011 | 06:02 PM
john v's Avatar
john v
Default t34 help
hi guys,what actuator do you use with a t34.48,its on a 4x4 saph,i dont mean -31 or -34 i mean is it an escort cossie one or is there one specifically for the t34,thanks john.
Old Oct 8, 2011 | 06:16 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
When I change from a T3 to a T34 on my cossie 4x4 I found that the shaft of the -34 actuator I used on the T3 was a bit to long to fit on the T34. So I cut of half an inch of the shaft so I could adjust it the right way. Hope this helps.
Old Oct 8, 2011 | 06:41 PM
john v's Avatar
john v
thanks for the info,modifiying the old one is an idea if i cant find out what the right one is,someone on here must know their a pretty clever bunch.
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
28
Sep 8, 2015 07:10 PM
