Fuel pump rewiring....
Old Sep 30, 2011 | 06:51 AM
SteveB's Avatar
SteveB
Default Fuel pump rewiring....
I know how to do it as I've done it before but my mine is a blank as to which wire goes to which pin on the relay....
Pins...
30/87a
85
86
87
Any help will be appreciated.
CheeRS
Steve
Old Sep 30, 2011 | 07:49 AM
Phil2002's Avatar
Phil2002
blue/white from ecu(pin28 i think from memory) - pin 85
ignition feed - pin 86
Fused supply straight from battery - pin 30
fuel pump + terminal- pin 87
the old ford black/red will also need to be connected to pin 87 as this also powers the iscv etc. make sure you isolate it boot end to prevent short circuit.
i used a Durite 40/70 amp relay part No. 0-728-70
hope this helps,
Phil
Old Sep 30, 2011 | 07:50 AM
Phil2002's Avatar
Phil2002
Thats for cossie by the way!
Old Sep 30, 2011 | 07:54 AM
martysmartie's Avatar
martysmartie
87 is the output and 30 will be the permanent live, i.e. what will be switched to power the pump, 85 and 86 are the relays inputs.
Typically the original relay is used as the trigger for the new relay, i.e. from 87 on the old relay to pin 85, 86 is a ground. Pin 30 should have your new FUSED live spur direct from the battery and pin 87 should be the output to the pump itself.
Remember to ensure the pumps ground connection has a good earth as well, this does not mean onto a rusty wheel well
Make sure to disconnect the batterys earth BEFORE you start any work!
Martin
Old Sep 30, 2011 | 08:04 AM
SteveB's Avatar
SteveB
Cheers.... Its for a Focus RS, I've done them for a Cossie in the past but had memory loss lol
Steve
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
