2 way or 3 way manual boost controler, bleed valve
as title, whats the pros and cons, im thinking that a 3 way controler will be noise on boost? and im thinking that a 2 way controler will be slow to control the actuator?
its for an rst,
thanks in advance
its for an rst,
thanks in advance
Again i didnt think there was a difference between manual controller and bleed valve. It just makes the ECU think it's seeing less boost than it is so the turbo produces more before the actuator does its bit.
I honestly dont know what the 3rd connection would be for. Unless its to connect to the ECU, the bleed valve would go between the manifold and actuator, i'd assume the ECU would be better having it's own vac line to the manifold though.
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
