2007 Mondeo starting problem
Old Sep 27, 2011 | 12:26 AM
Novice mec's Avatar
Novice mec
Default 2007 Mondeo starting problem
I'm in need of help please??
My dads 57 plate Mondeo tdci won't start from cold. As normal you do your normal turn key so glow plugs light up wait for them to go out (about 15 seconds when engine cold) then try to start the engine turns over fires then dies after not even a second? But when you get it going and engine has run when you start it later glow plugs go of as soon as it comes on and starts fine. Changed the diesel filter then would not start rac man said it was no pressure in fuel pump but but after he left we bump started it and ran and runs fine any suggestions would be brill! Some days she will start on key from cold (after about 10 attempts )
Old Sep 27, 2011 | 01:43 AM
12340987's Avatar
12340987
Injectors are knackered, well maybe one or two of them. need to be coded or something. not cheap.
Old Sep 27, 2011 | 09:06 AM
Novice mec's Avatar
Novice mec
But it runs fine no real bad smoke a bit but not a lot only when put foot down surely would not run fine when started could it be anything else?
Old Sep 27, 2011 | 09:30 AM
kmustafa's Avatar
kmustafa
I am not a mechanic but I has a similiar problem and intially I cleaned EGR valve where it was fine for a bit and then replaced it with a new one.You could try that it's not to difficult to dismantle,clean and refit.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
The Enigma
13
Aug 20, 2015 09:38 PM
nick8saff
Aug 16, 2015 05:35 PM
taylora1409
Aug 12, 2015 12:06 PM
