what turbo after a T4 ?
Old Sep 25, 2011 | 08:47 PM
boost mad's Avatar
boost mad
Default what turbo after a T4 ?
bored of the T4 now and the power it can produce, whats the next option ?
Engine is 7.3:1
26.5mm inlets 24.4mm exhaust ports,
BD16 inlet cam
So what are my options and potentual power outputs
Old Sep 25, 2011 | 08:51 PM
cossyking's Avatar
cossyking
Engine is 7.3:1
BD16 inlet cam
thats when it gets expensive mate, prob gt series or something like a t04z depends what power you want we specced a turbo t4 based that made 568 bhp
Old Sep 25, 2011 | 09:11 PM
boost mad's Avatar
boost mad
Well im hoping my T4 would be worth abit, its done about 1000 miles since rebuild and about 500 since it had a new exhaust housing. 360 bearing and Mar-m shaft too.
Nothing definate yet, as i have a few other things to get before i can entertain more power but i just want to know my options!
Old Sep 25, 2011 | 09:17 PM
cossyking's Avatar
cossyking
depends how deep your pockets are mate but over 600 bhp is big bucks trust me im there now lol
Old Sep 26, 2011 | 09:20 AM
boost mad's Avatar
boost mad
deep pockets? i dont even have pockets lol.
im currently running 2.3 bar on the above spec, not sure on power, i just know its not enough lol.
Old Sep 26, 2011 | 05:55 PM
105epwr's Avatar
105epwr
Stick 100+bhp nos kit on it
Pick and choose when you want the extra hit then!
Old Sep 26, 2011 | 06:36 PM
opposite lock's Avatar
opposite lock
There,s some impressive engines on here using GT 40,s and 42,s etc
Old Sep 26, 2011 | 06:42 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
imo your looking at gt 35 upwards,and thats with a large rear housing ,
what price you got in mind for the t4 fella?
drop me a pm please
beef
Old Sep 26, 2011 | 06:44 PM
Mark Shead's Avatar
Mark Shead
Engine is 7.3:1
BD16 inlet cam
You need to look at full car spec rather than the small details you have posted and also what hp you are after to be able to advice.
Mark
Old Sep 26, 2011 | 07:04 PM
BRAMMER's Avatar
BRAMMER
I have a GT30, 16 cam etc and i'm expecting mine to be on the limit for a usable road car - where beyond that spec you have already can you use to it's full potential, i know what you have is wild for the road but the next step your talking big HP and is it worth the massive expense for a complete re spec?
unless you do track
Old Sep 26, 2011 | 07:44 PM
v man's Avatar
v man
Zee Germans are coming
put a t3 on for a while then go back to the t4
swap them about here and there
could save a few quid
or 4k get your self a gsxr 1000 and never get bored
Old Sep 26, 2011 | 08:52 PM
boost mad's Avatar
boost mad
Mark
What more would you need to know Mark ?
I dont have a figure im after as im not chasing numbers, its just a matter of wanting more.
unless you do track
I will still be used on the road so dont realy want to be having a race engine spec if that makes sense. I was just thinking that a turbo change could release a few more hp ?
Old Sep 26, 2011 | 09:18 PM
J1mbo's Avatar
J1mbo
B1mbo
Well, a t4 is pretty identical in terms of out right power as a gt30, so the next step would be something gt35 sized (I wouldnt tell you to use one, but before Mark jumps on me, he would ) and really you need to be doing some serious work to make it proper, you could carry on with your STD rods and mahles?
Or, you could do a proper bit of t4 engine, nice pair of cams, up the comp ratio as that's too low, and a good inlet manifold, get it mapped and enjoy, were doing 540 t4 engines that are fantastic, and that's not too much cost to do that, the next step is
Old Sep 26, 2011 | 09:27 PM
boost mad's Avatar
boost mad
Rods are standard but the pistons, albeit it mahles, are aftermarket fordged ones with cut outs. ( its one of your old mans engines Jim
Old Sep 27, 2011 | 07:19 AM
J1mbo's Avatar
J1mbo
B1mbo
Is it a waples head?
A pair of cams in that and up the comp ratio would make a nice engine, infact similar to what I'm putting in my 2wd saff.
Other wise it's a case IMO of cams, turbo and inlet change but there's no real bridge turbo between t4 and something gt35 sized :/
Old Sep 27, 2011 | 07:54 AM
Turbosimpsons's Avatar
Turbosimpsons
now! thats a good idea.
Old Sep 27, 2011 | 05:31 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
M8 you gotta bonkers if you have a T4 maxed out and you need more power for the road lol
Steve
Old Sep 27, 2011 | 06:34 PM
Mark Shead's Avatar
Mark Shead
Myself I would limit the stock rods to 550hp so I would either change the spec slightly and max out the T4, Or change the turbo and manifold to a BW 200SX.
Mark
Old Sep 27, 2011 | 10:01 PM
boost mad's Avatar
boost mad
The headwork was done by Neil Roper
Mark
If thats the limit of the rods then i wont be going much higher power wise as i dont want to be pulling apart the engine at the moment.
Currently on a 2wd exhaust manifold and an EEC4 inlet.
Old Sep 30, 2011 | 05:55 PM
cossie daz's Avatar
cossie daz
Oh alex
I feel there maybe trouble ahead
Old Sep 30, 2011 | 07:18 PM
boost mad's Avatar
boost mad
when isnt there lol
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
