Cossie 4x4 - wheel hub bearing
Old Sep 24, 2011 | 11:01 PM
kaisersolsay's Avatar
kaisersolsay
Default Cossie 4x4 - wheel hub bearing
The wheel bearing seems loose inside the centre piece of my front wheel hub, as the hub with the wheel studs freely moves in and out and can be wobbled up freely around side-to-side. Is the bearing goosed? When fitted to the car and the wheel fitted there is a mental amount of play. I do not have the from driveshaft fitted yet so perhaps this is the issue?
Old Sep 25, 2011 | 06:34 PM
kaisersolsay
Anyone?
Old Sep 25, 2011 | 06:43 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the bearing is held in place by the cv joint thing, so if this isn't in there then it won't be right
if it is then you have a fucked bearing
they are a bit fiddly to fit too
Old Sep 25, 2011 | 07:00 PM
Bailes1992's Avatar
Bailes1992
The CV joint along with the hub nut keeps everything solid and together. Without this you will have play
Old Sep 26, 2011 | 10:54 PM
kaisersolsay
Thanks lads
Old Sep 30, 2011 | 06:38 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Lol I had the same worry when I changed a drive shaft and thought the same thing till I bolted the cv joint back onto the hub.
Old Oct 3, 2011 | 10:38 PM
kaisersolsay
Cheers lads
DixieTheKid
Jul 23, 2023 10:16 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
vdubo7
Aug 2, 2015 08:17 PM
muz
Aug 1, 2015 06:48 AM
Old ford
Jul 31, 2015 06:50 AM
