Zetec Turbo and MK6 Van parts..
I have few bits for sale from my Zetec Turbo project..
lowered rear axle, shackles, 3 leaf conversion £100
Brake pedal box, straight fit to MK6, willwood cylinders £120 inc.pedal box, remote adjuster, all fittings..
Zetec fuel rail, 550cc TRD injectors, with plugs/wire £100
Full Stainless Steel 3" exhaust with 3.5" rolled tail pipe, for MK6 Van (down pipe not included) £150
130 H.O inlet, with Granada Throttle body, cable for MK6, bolts (may need new Idle valve and Temp sensor, I never used the, as I was on aftermarket management..) £100
Helix paddle clutch, less than 200mls £200
Zetec 2.0 head, with Newman HD valve springs £100
Zetec 1.8 lighten/balanced/ skimmed flywheel £100
Zetec Turbo (Focus RS) forged pistons/rods slight marks on one £200
Van Tinted rear lights, £20
