Cam lube
Old Sep 23, 2011 | 11:59 AM
BRAMMER's Avatar
BRAMMER
Default Cam lube
question regarding fitting cams -
Can you fit the cams into the head and leave it - basically once you have applied the lube are they fine to sit for a while
The bottom end isn't yet built so they will be sat for a few weeks so will the cams still be lubricated at the later date?
I know FMC used to have complete engine in pallets which is kind of the same
Old Sep 23, 2011 | 12:53 PM
dug112y's Avatar
dug112y
passionford pro
yeah should be fine matey.
Old Sep 23, 2011 | 06:24 PM
stevieturbo's Avatar
stevieturbo
C**t
I wouldnt worry about it. Cam lube was more of an issue with old flat tapped engines. The lifters had small contact areas, can journals often narrow and generally oil supply wasnt great.
Modern OHC engines with big diameter lifters it really isnt that important. Just oil them up After sitting for a few days it will be no different than your own car parked up for a few days.
Old Sep 23, 2011 | 07:18 PM
BRAMMER's Avatar
BRAMMER
Cheers for the info lads
Old Sep 23, 2011 | 07:27 PM
stevieturbo
C**t
But if you really want to use something, Torco make an engine lube which is similar. Cam lube of old was like a very thick gear oil.
Old Sep 23, 2011 | 08:30 PM
COLEYST200's Avatar
COLEYST200
its all ok wot your going to do mate just when its all togever leve the dizzy out and prime the motor with a drill that will put oil all round the motor with out hitting the key
Old Sep 23, 2011 | 10:18 PM
BRAMMER's Avatar
BRAMMER
Col, was speaking to Dave Pritchard at ND and he was saying the same
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
