bent conrod on vw tdi?
Old Sep 23, 2011 | 02:18 AM
andy130's Avatar
andy130
Default bent conrod on vw tdi?
anyone know what causes them to bend? is it a engine replacement?
Old Sep 23, 2011 | 05:01 AM
Mark RS's Avatar
Mark RS
Has it been driven through a puddle,and sucked up water
Old Sep 23, 2011 | 01:12 PM
Rax's Avatar
Rax
Agreed probably water ingestion .
Old Sep 23, 2011 | 04:30 PM
Icurus's Avatar
Icurus
Too much boost can bend rods too, but most likely to be water, either from a puddle as suggested, or head gasket leak?
Old Sep 23, 2011 | 10:32 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
too much fuel/too much boost causes knock which causes bendings
my 2.2 20vT 5 pot motor is limited by bottom end torque as that bends rods from shit setups causing detting/knocking and subsequently bent rod that then exits the block without warning
Old Sep 23, 2011 | 10:48 PM
JamesH's Avatar
JamesH
Was it remapped?
Old Sep 23, 2011 | 11:02 PM
cossyking's Avatar
cossyking
usually injector problems on vw to much fuel and they hydraulic and bend rods is it a t5 there most common
Old Sep 24, 2011 | 01:45 PM
andy130's Avatar
andy130
thanks guys, its a 115bhp bora pd engine, the turbo let go on it a few weeks back, theres two rods bent from what i can see
Old Sep 24, 2011 | 01:49 PM
rs clint's Avatar
rs clint
insane
set light to it send it down the scrappy
3i_gaz's Avatar
3i_gaz
VERY common on the 20vt VAG lumps when your running big torque.
Sounds like that to mee if it hasnt sucked up water
Old Sep 24, 2011 | 04:17 PM
Mark RS's Avatar
Mark RS
it sounds like it has run on on its own oil,was the turbo changed?if so did you clean out intercooler etc?
Old Sep 24, 2011 | 04:35 PM
RST's Avatar
RST
When is water been sucked up normally does number 1 rod.
Old Sep 24, 2011 | 07:39 PM
Fullflush's Avatar
Fullflush
When the turbo goes it can hydraulic the engine with oil.
Old Sep 24, 2011 | 07:42 PM
andy130's Avatar
andy130
cheers guys two bent rods
Old Sep 25, 2011 | 10:04 AM
Fullflush's Avatar
Fullflush
Ouch... good luck getting it sorted
Old Sep 25, 2011 | 11:10 AM
Bailes1992's Avatar
Bailes1992
Heard of one a few months ago which had an injector stick open and the engine hydrolocked on it??
155lee
Oct 27, 2015 04:55 AM
AJC
Oct 1, 2015 06:47 PM
SMILER258
Sep 28, 2015 09:04 AM
Mr S1
20
Sep 27, 2015 04:06 PM
BRAM
Sep 8, 2015 07:11 AM
