boost presure
Old Sep 21, 2011 | 08:12 PM
ethan89's Avatar
ethan89
frst
Default boost presure
hi guys what psi should you run when using 195 superchip and beige injectors?is it 14 or 16? dont want to blow anything up or run to rich or lean
Old Sep 21, 2011 | 08:23 PM
paul0461's Avatar
paul0461
well you cant run more then a bar i dont think.
so 14
Old Sep 22, 2011 | 12:06 PM
ethan89's Avatar
ethan89
frst
is that cos of the limitations on the chip?
Old Oct 22, 2011 | 09:47 PM
JJ24's Avatar
JJ24
Anymore than 14psi the fueling goes too lean as i found out. Even at 14psi the fueling can be off. MSD chip is soo much better. If you want to use the 195 get your fueling checked. Jamie
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
