Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
remote locking problem
Old Sep 21, 2011 | 07:42 PM
m4r71n's Avatar
m4r71n
Default remote locking problem
got a weird problem with the locking on my focus, if i use the remote it only unlocks the passenger doors and not the drivers one. if i use the key it unlocks all of the doors fine. could this be an actuator problem and is it an easy fix. thanks in advance
Old Oct 4, 2011 | 07:44 PM
Cozziekid's Avatar
Cozziekid
Probably needs a new door catch mechanism, common problem.
Old Oct 4, 2011 | 07:46 PM
RichieST's Avatar
RichieST
Try having a good old squirt around with wd40 first all around the lock, inside key hole etc. Take the door panel off if you can and squirt any moving parts.
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
