E6 funny knocking on tight right corners
Old Sep 19, 2011 | 09:11 AM
morto's Avatar
morto
Default E6 funny knocking on tight right corners
Hello all , im trying to sort out what the strange noise is when im turning right, it only happens when im on really tight right hand bends pushing the car hard say when i go around a roundabout at speed, its like a pulsing i can feel thru the steering wheel? the abs and ayc lights are on but cant work out weather its got anything to do with the abs, ive checked the front ABS Reluctor Rings and there is no cracks in them , but was maybe thinking the front driveshaft ? any thoughts on this please
Thanks
Andy
Old Sep 19, 2011 | 09:46 AM
Robs Frst's Avatar
Robs Frst
Have you checked the front diff bolts, located in the transfer box?
There known to snap or work loose, which will give you the symtoms when changing direction.
Also when did you last have your Ayc fluid changed?
Old Sep 19, 2011 | 09:57 AM
morto's Avatar
morto
thanks rob yes i did think of the diff bolts mate, but was thinking why only on right corners and not left ?
thanks
Andy
Old Sep 19, 2011 | 10:08 AM
Robs Frst's Avatar
Robs Frst
thanks
Andy
They can knock at any direction mate only thing Transfer box has to be dropped, another thing to check , top mounts, lower arm bushes, antiroll bar bushes and shocks. Nice Excuse to upgrade to Ralliart Items
What suspension set up are you using?
Done mine with a Fast road geometry set up, feels great.
Old Sep 19, 2011 | 11:05 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Sounds like diff bolts. I'm sure my friends one only knocked in 1 direction.
Old Sep 19, 2011 | 11:09 AM
morto's Avatar
morto
Rob they can be done insitu a few lads on MLR have done it and say theres no need to take the whole transferbox out, iv got tein suspension all round
Thanks
Old Sep 19, 2011 | 11:30 AM
Robs Frst's Avatar
Robs Frst
Thanks
That's new to me, learn something new everyday.
Tein are notorious for knocking also, had to have mine rebuilt So worth checking.
Old Sep 19, 2011 | 11:43 AM
morto's Avatar
morto
Will try and find the link on MLR pal !! think some traders also do them insitu
Andy
Old Sep 27, 2011 | 02:59 PM
morto's Avatar
morto
have a look at the update on this turns out i have evo 5 driveshafts in a evo 6 , 13mm to big either side
http://www.lancerregister.com/showthread.php?t=388881
Mark RS
Mar 5, 2021 06:08 PM
tankybaby66
Feb 6, 2016 02:24 PM
gingeRS
17
Oct 2, 2015 09:42 AM
BRAM
Sep 8, 2015 07:11 AM
