2006 Mondeo ST rear wiper
Old Sep 18, 2011 | 02:36 AM
Brian's Avatar
Brian
Default 2006 Mondeo ST rear wiper
I have just bought a 2006 mondeo ST estate and rear wiper isn't working? The washer jet works but the wiper wont anyone got any ideas?
Cheers Brian
Old Sep 18, 2011 | 12:50 PM
Brian's Avatar
Brian
Anyone?
Brian
Old Sep 18, 2011 | 01:06 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Does it make any noise? It could be the motor as they do 'go'. Take the rear panel off and check the voltage to the motor.
Also (and this is a bit geeky) while you're at it swap the wiper arm for one from a Mk5 Astra Estate. It's a straight swap and looks a lot nicer than the spindly standard one.
Old Sep 18, 2011 | 01:32 PM
Magnum PI's Avatar
Magnum PI
Could be a knackered relay?.
Had similar problem with my focus and it just needed a new relay.
Old Sep 18, 2011 | 01:42 PM
Paul_RS's Avatar
Paul_RS
Are these canbus operated? If so may make tracing wiring faults a bit harder
Old Sep 18, 2011 | 02:55 PM
RichieST's Avatar
RichieST
With the front wipers on, put it in reverse. If wiper still doesn't come on then it is a fault with the wiring/motor and not the switch.
Old Sep 18, 2011 | 03:25 PM
Brian's Avatar
Brian
Cheer's lads have checked the voltage at the plug and its getting 12v pluged the motor in from my hatch back mondeo and it works so need to get another motor.
Dan any pictures of a Mk5 Astra Estate one?
Cheer's Brian
Old Sep 18, 2011 | 07:15 PM
DanW@FastFord
Spelling Club King!
It's not my pic, but it looks like this...
Much nicer than the weedy Mondeo arm.
Old Sep 18, 2011 | 11:07 PM
Brian's Avatar
Brian
Does look smart Dan
Brian
Old Sep 19, 2011 | 08:15 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Like mine
Anyway, when you do decide to remove the arm, make sure you donit with a proper pulled as yanking the thing off will upset the position of the arm and it will never be right again.
Obviously this is more a case of doing it to the replacement motor than your one but it's worth the patience.
As for removing the motor, you have to CAREFULLY pride out the upper surround first starting with the brake light then the side trim panels and then the lower large panel because I'd you yank and tug the chances are you will snap one of the locating lugs
The wiring should be fairly straight forward as it's plug and play but there are so many other diddly wires there you may get a litre confused with everything
If you've already removed the cover then all well and good but you know this subject will crop up again and it's always best to be well informed
Old Sep 19, 2011 | 08:16 AM
dojj's Avatar
dojj
And before I forget, the arm and wiper blade are about Ł11 in total from vauxhall
Old Sep 19, 2011 | 08:49 AM
DanW@FastFord
Spelling Club King!
Originally Posted by dojj
Like mine
Nah, just give it a wiggle!
Poor pic, but here's mine -
Old Sep 19, 2011 | 10:27 AM
dojj's Avatar
dojj
Mine was stuck on good and proper, I even tried using a slide hammer and nothing shifted it so I ended up using some bearing pullers which finally managed to shift the bastard
Old Sep 19, 2011 | 10:28 AM
dojj's Avatar
dojj
And how much did thetints set you back then? I spotted your sly attempt to gangsta your ride in the mag
Old Sep 19, 2011 | 11:19 AM
DanW@FastFord
Spelling Club King!
They're not that much darker than the OE Ford tint to be honest! It just looks dark in pics...
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
rex647
Mar 6, 2022 06:20 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
