Fitting Dash2- stopping ford ECU checking on start up
Old Sep 15, 2011 | 07:07 PM
SiST's Avatar
SiST
Default Fitting Dash2- stopping ford ECU checking on start up
Hi
This one is probably more for the ford ECU gurus or electricians on here - I am fitting a dash2 display this weekend and i want to bypass the ford CANBUS system in the fiesta ST so that the ECU does not check that the dash cluster is there when starting the car as currently the car wont start with the Dash2 on it due to this.
I have got a omex 600 for the engine but have kept the normal ford ECU for all the other areas.
Any ideas guys? My idea is to fit a Ohm resister which I did with the airbags previously but i am not sure if it is applicable here and am a wiring noob lol
Thanks, Si
Old Sep 15, 2011 | 08:35 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
a resistor wont work because the canbus sends a digital message. Might be easier to rip it all out to be fair.
Old Sep 15, 2011 | 10:43 PM
stevejones12's Avatar
stevejones12
Just seperate the PCB from the dash removing all the plastic ...be brutal then hide the PCB behind the dash connected to the ecu.
Chuck it inside a suitable plastic box to protect it. Job jobbed !
Old Sep 15, 2011 | 10:54 PM
B19LRW's Avatar
B19LRW
Its Broken.....
Sounds like advice from a ECU monitor enthuiast!
Dr. Ickxs
Aug 15, 2015 11:34 AM
Aug 10, 2015 12:08 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
