best on 2.0 pinto- side draft carbs or fuel injection?
Old Sep 14, 2011 | 08:02 AM
Dawie's Avatar
Dawie
Default best on 2.0 pinto- side draft carbs or fuel injection?
Hey can anyone tell me what is the best option on the 2.0 pinto and which 1 will give me more bhp?
Old Sep 14, 2011 | 09:15 AM
Weeksy's Avatar
Weeksy
Carbs will ultimately- if 45's, but it depends how far you want to go with it.
A nice torquey cam in a cleaned up head with a 4 branch on efi will make 135 or 140, and still be lovely and drivable round town.
After that it's side draught territory and all the expense of them!!
Thanks
Weeksy
Old Sep 14, 2011 | 10:22 AM
Dawie's Avatar
Dawie
Thanks
Weeksy
Would it be okay if I want to go turbo later?
Old Sep 14, 2011 | 10:33 AM
Weeksy's Avatar
Weeksy
I have heard of people turboing the Efi with aftermarket management ( the ford stuff won't cut it with boost as far as i am aware. Cossie management might cut it!!
With carbs it's rarely done unless the carb used was originally used for a turbo, as you get boost leakage above about 10 psi or so, and / or pressuring of the fuel and all sorts of running issues!
Thanks
Weeksy
Old Sep 14, 2011 | 10:34 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Your best bet is programmable EFI, either throttle bodies or single throttle body. Carbs will not make more/less power than throttle bodies of the same size, the advantage of programable EFI is that it can be mapped infinitly to suit every load postion of your set-up. Unlike carbs that will have very few adjustments and will not be perfect under evry load condition. EFI is best if going down the turbo route, carbs have too many complications with turbos and are notoriously hard to tune
JamesH
Sep 2, 2015 10:02 AM
Russ Hill
Aug 31, 2015 06:44 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
borboyous
Aug 22, 2015 11:17 AM
mick pearson
Aug 9, 2015 09:19 AM
