Help! Fuel flap not opening on MK3 mondeo!
Old Sep 13, 2011 | 10:52 PM
MHunt's Avatar
MHunt
Default Help! Fuel flap not opening on MK3 mondeo!
Title says it all, it was working fine up but today when I was going to fill up, it wouldn't open up.
The lever lifts up a lot higher than normal and has less resistance, but when I lift it up I can hear a noise coming from the flap area, it's just not opening.
Anyone know what's up? I only just had enough fuel to get back home....
Old Sep 13, 2011 | 11:47 PM
botters's Avatar
botters
competant bodger
im sure there is an emergency release behind the drivers side rear boot trim, its probably the cable has either snapped or come adrift
Old Sep 15, 2011 | 10:36 PM
Goofygolfer's Avatar
Goofygolfer
as Botters said, look behind the trim in the boot.
Old Sep 16, 2011 | 08:26 AM
MHunt's Avatar
MHunt
I did, the cable had come loose and come out of the clips. Thanks guys!
Old Feb 23, 2012 | 03:59 PM
jonewer's Avatar
jonewer
Hi, thought I'd resurrect this old thread as I seem to have the same problem.
Only thing is that the cable still seems to be very much attached to its moorings in the boot, yet it still wont open.
Any ideas?
Old Mar 7, 2012 | 07:22 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Any ideas?
Get someone to try and gently prise it open while you pull up the catch. It should pop open.
andyrs1600i
Apr 29, 2026 03:21 PM
JK12
33
Apr 26, 2021 12:09 PM
Chas
Sep 21, 2015 08:57 PM
Alun Gregory
Sep 6, 2015 09:40 AM
Bailes1992
Sep 3, 2015 02:17 PM
