Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Engine change fiesta mk6
Old Sep 13, 2011 | 05:03 PM
Johnboy357's Avatar
Johnboy357
Default Engine change fiesta mk6
Hey i have a mk6 fiesta 1.25 duratec and i need a new engine im not sure if an engine swap would be straight forward swap or if i'd need to change all the ecus and stuff? Thanks
Old Sep 13, 2011 | 05:32 PM
martysmartie's Avatar
martysmartie
Larger displacement of the same engine shoulden't be to hard, i.e. the 1.4 or the 1.6, I would personally go for the latter, as your current engine and the 1.4 do in fact have the same power output, although the 1.4 does have more potential in it.
The 1.6 is the engine which is fitted to the "Zetec-S" sporty Fiesta offering, and is also in the Focus, Cmax etc.
You probably need to change the ECU though, as the mapping will be different.
Martin
Old Sep 14, 2011 | 11:15 AM
Johnboy357's Avatar
Johnboy357
Thanks for the help
Old Jun 26, 2013 | 03:39 PM
nnnnnnnt's Avatar
nnnnnnnt
Hi guys
I was reading this old topic about going from 1.25 fiesta to 1.4 .
I wanted to know if this worked??? because im doing the same,but the ford dealer told me that i might have some issues with the car key,he will not reconize the 1.4 ecu and the car may not start.
Did you have any problem doin this? i got a ford fiesta mk6 2003. the 1.4 mk6 engine i wanted to buy looks the same,(same plugs etc)
i'll really aprecciate your help!!
Thanks
Old Jun 28, 2013 | 12:22 PM
martysmartie
It will recognize the key providing you keep the same ECU.
But personally, don't bother, as a point of trivia the 1.25 is as powerful as the 1.4, the latter was more powerful but was de-tuned for emissions purposes.
They are indeed the same engine, that being the Zetec SE, just larger in displacement, as is the 1600 engine fitted to the Zetec S and Focus etc.
It will be cheaper and easier to buy something more powerful outright.
Martin
Old Sep 6, 2013 | 02:37 PM
R13AAD's Avatar
R13AAD
Hi guys,
Ive got a mk6 fiesta 1.4 black and the engine has seized so im looking to put the 1.6 zetec s engine in there. I don't know how to make a new thread so I though id ask on here as its a similar topic.
What I need to know is if the engine will fit straight on to the 1.4 gearbox and whether the gearbox can handle the power etc
Does anything else have to be changed? i.e driveshafts etc? I know the brakes and suspension has to be changed and the ecu but Im not sure if the block will fit onto the gearbox..
thanks
Old Sep 6, 2013 | 09:27 PM
martysmartie
The engines are the same, and so is the box.
You may be ok with the suspension, I mean there is mininal weight difference between the two, although the brakes might be a good idea as you will have more power.
Martin
Old Sep 9, 2013 | 04:45 PM
R13AAD's Avatar
R13AAD
Martin
Okay thanks but I need to change the loom n ecu right? Apparently I have to get the key programmed too..? Where can I get a loom n ecu from or even better an engine which comes with the ecu n loom? Thanks
Old Feb 6, 2016 | 03:09 PM
Kanepr's Avatar
Kanepr
Hi, I've been reading this thread. I have a 1.4 flame. If I was to do a conversion to a 1.6 am I right in thinking the block is the same? If so is stroke or bore that's different?
How easy is it to convert a 1.4 to a 1.6?
Old Apr 26, 2017 | 11:46 AM
Gjjames's Avatar
Gjjames
Default Just wondering if anyone nose about the ford feista 1.6 diesel
I have 2010 Ford Fiesta 1.6 titanium diesel and the engine is seized so am looking to replace the engine block with a one from a salvage yard just wondering if it's a straight forward swap as al be replacing my old engine block and injectors for the new block what comes with pump & injectors if it's came from the same type car with same engine codes Will it work ? Thanks
Old May 31, 2017 | 05:09 PM
Connor Hill's Avatar
Connor Hill
Default Ford fiesta
I have a 1.25 and I want to put a 1.6 zetec engine in. Will it be as simple as just changing the engine over? Or will i have to change the ecu or any other things like that?
Thanks
Old Jun 3, 2017 | 11:01 AM
martysmartie
Thanks
You would need a remap or the ECU, as the mapping will be completely different.
Martin
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
