4x4 cossie
Old Sep 12, 2011 | 05:12 PM
P4ULT's Avatar
P4ULT
Default 4x4 cossie
hi guys ive just purchased a k reg cossie what are the first things/ checks i should be doing. is there anything you guys check on a regular basis?also what oil is best to use< the car is pretty much standard apart from a full exhaust system. i may up the power later on but id like to use as is at the moment. where is the best place around /near bristol to get things done. also any alarm reccomendations.
sorry for the long post regards
paul
Old Sep 12, 2011 | 05:27 PM
Staffi's Avatar
Staffi
Hi Paul, i'd say make sure the wiring etc is all good firslty. If you're going to up the power and you buy a chip then get someone who knows what they're doing to set the car up for you, fueling etc, hasn't it got an Alarm then??
Old Sep 12, 2011 | 05:32 PM
P4ULT's Avatar
P4ULT
it has but could do with a new one
P4ULT's Avatar
P4ULT
also what fuel do you guys use
Old Sep 12, 2011 | 05:58 PM
xr_craig's Avatar
xr_craig
Always run mine on v-power. Personally i'd give it a good service and get it booked in for a setup. Always better to be safe than sorry and it should highlight any potential issues.
Old Sep 12, 2011 | 06:05 PM
martysmartie's Avatar
martysmartie
I would firstly do a service and change the oil, this would be true of any car I brought!
Anyway onto the car itself, firstly you want to check your fans have been rewired, and if not do so.
The fan wiring was substandard when new, leave alone now and it's a surprise if the fans do actually work on the standard wiring, usually the fuse melts in the fusebox.
You can buy looms pre made from MSD etc, or it's easy enough DIY if your good with electrics!
The fuel pump wiring also suffers with age as it builds resistance, thus the pump cannot draw the power it needs and so you can end up with a meltdown!
The above are two chronic weak points!
It depends what it's mapped for really but I just use standard unleaded.
I think "Reyland" may be near you.
Toad alarms are quite well rated (I believe the AI06) is the model in particular, I personally have a Clifford which also get quite good reviews.
Personally I woulden't have anything other than a Cat 1 system!
I assume you do have a current solution otherwise I should think no one would insure you!
Is it standard at the moment? If so thats very rare, but if it is the next logical step would be a stage 1 conversion, this is the easiest conversion, merely requiring a re-map, this will see circa 280HP and importantly more torque!
Martin
Old Sep 12, 2011 | 06:34 PM
P4ULT's Avatar
P4ULT
im pretty sure its standard maybe a little extra power from the exhaust.
the fan works but i did notice in the fue box a wire going from one fuse to another.
how do i tell if the fuel pump wiring is sorted.
oil anf filter is on the cards what oil is reccomended?
although the oil should e ok as it s had a top end rebuild but im gonna do it anyway
power wise im gonna drive it for a bit first may get an induction kit. i have not actually driven the car yet due to having a knee op and been on crutches for the last for weeks anfd for at least 2 more. and its driving me mad
Old Sep 12, 2011 | 06:44 PM
martysmartie
Mobil 1 15W/50 or Fuchs 10W/50, i use the latter, these are both popular choices!
You need to measure the power at the pump WITH the engine under load, i.e. a voltmeter wired to the pump inside the car, whilst giving it a bootful. You should ideally see alternator voltage, but anything less than 12V is the danger point.
The wiring in the fuse box certainly sounds dodgy and I would advocate investigating it!
Martin
Old Sep 12, 2011 | 06:59 PM
P4ULT's Avatar
P4ULT
i will look into it see what it does
Old Sep 12, 2011 | 07:41 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
all good advice. would deffo take a trip to Martin once you up the power a bit
Old Sep 12, 2011 | 07:49 PM
R5COS's Avatar
R5COS
Apart from all the usefull tips above, i would get under the car and have a good poke about make sure its solid in all the right places, give it a good steam clean etc...
And while under there id change the oil in the diffs and gearbox as you never really know when these were last done...
And flush the coolant and top it up with winter round the corner you can never be to carefull... Best of luck with the car by the way
Old Sep 13, 2011 | 08:20 AM
P4ULT's Avatar
P4ULT
i notice your from bristol is this who you use.
Old Sep 13, 2011 | 08:21 AM
P4ULT's Avatar
P4ULT
ill check the paper work but im sure its been done in the last couple of years.
coolant is a good tip, do you mean steam underneath the car.
Old Sep 13, 2011 | 11:22 AM
R5COS's Avatar
R5COS
Yep get rid of all the old dirt/muck and oil etc
Old Sep 13, 2011 | 11:25 AM
Congrats on buying a saff.I hope you enjoy it.
Old Sep 13, 2011 | 02:28 PM
cossie891's Avatar
cossie891
Another 1 in bristol then I will keep my eye out for you mate
Old Sep 13, 2011 | 03:08 PM
sierrsteve1980's Avatar
sierrsteve1980
I have had issues with the standard fan loom, just ordered a new one. I have changed most of the wiring now. Engine loom with a built in fuel pump loom. It's made all the difference.
Good luck with it, hope it don't give u the grief I have had with mine. Mine is all sorted and they are great cars.
Old Sep 13, 2011 | 03:18 PM
R4N SS's Avatar
R4N SS
if you need parts for the cossie, go and see Gary @ RS Classics as he is round the corner from you.
As above, service it, possibly even change the belt and tensioner and take it for a set-up - any decent place should be measuring the voltage from the pump so you will soon know if its not drawing enough current.
Fuel pump looms are around 50-60 i think
Ive just ordered a fan loom from Paul @ NYRS and he does two different types - i went for the newer sooper dooper 2 stage fan kit which is £68 plus delivery.
Old Sep 13, 2011 | 06:11 PM
P4ULT's Avatar
P4ULT
Cheers for the advice guys it all helps.
Old Sep 13, 2011 | 06:12 PM
P4ULT's Avatar
P4ULT
what car you got ill keep my eyes peeled
Old Sep 14, 2011 | 07:51 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
I do all my own work, if you ever want a hand with yours, gimme a bell.
As for tuners, had mine checked over at Reyland last year
Old Sep 14, 2011 | 08:04 PM
cos 4x4's Avatar
cos 4x4
for servicing your nearest place in bristol will be interpro
Old Sep 14, 2011 | 08:30 PM
LHD220Turbo's Avatar
LHD220Turbo
wouldnt trust them with a push bike
Old Sep 15, 2011 | 08:00 AM
P4ULT's Avatar
P4ULT
cheers mate thats very kind may be calling on you for a few pointers, with some of the above advice.
i have had work at interpro before on another car and was not overly impressed.
Old Sep 15, 2011 | 09:31 AM
cossie891's Avatar
cossie891
I got a white 3 door mate but wont be on the road this year sadly
Old Sep 15, 2011 | 06:37 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
no worrys dude, drop us a pm and pop by
Old Sep 15, 2011 | 06:58 PM
P4ULT's Avatar
P4ULT
as soon as i can drive again ill be in touch be nice to meet a fellow rs owner.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
