Megasquirt for Zetec Turbo
Old Sep 9, 2011 | 12:11 PM
tocca's Avatar
tocca
Default Megasquirt for Zetec Turbo
Been looking at the megasquirt kits on Trigger-Wheels., specifically this one : http://trigger-wheels.com/store/contents/en-uk/d31.html Im going to be using an HO inlet. What other bits do I need to go along with this? Any other sensors etc? Am I better spending a bit more and getting the Wideband Controller and Sensor? Im completely new to Turboing and any help is appreicated
Old Sep 10, 2011 | 10:00 PM
tocca's Avatar
tocca
Is it worth getting a wideband lamba setup?
Old Sep 10, 2011 | 10:06 PM
studabear's Avatar
studabear
will you be mapping it yourself? wideband is essential
Old Sep 11, 2011 | 07:57 AM
tocca's Avatar
tocca
No mate I don't have the first clue about mapping. So if I ain't mapping it I won't need wideband?
Old Sep 11, 2011 | 08:36 AM
studabear's Avatar
studabear
I'm sure I will be corrected if I'm wrong, from what I've read you won't need it once its mapped, so as long as the mapper has wideband you should be fine.
If you do have a wideband you could run a afr gauge tho, something goodto keep an eye on.
quite a few of the lads in the rs turbo section are running squirt now, plenty of help there.
Cheers Stu
Old Sep 20, 2011 | 12:43 AM
inis's Avatar
inis
Yes you'll want a wideband with or without tuning it yourself. Megasquirt will adjust accordingly if wideband changes to much while driving (tune is off).
Also why are you looking at trigger kits, does your flywheel not had a trigger wheel behind it?
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
