Escort RS1600i This forum is for all things about the Escort RS1600i
rs1600i wont start
Old Sep 8, 2011 | 08:09 PM
dico009's Avatar
dico009
Default rs1600i wont start
hi guys, looking some help, my rs1600i wont start, the fule pump is working and on turning over the car tries to start then just floods itself, it will start on a tow and when running will start ok when warm, its just on initial start that it will not go. anyone know what the issue may be
please
Old Sep 9, 2011 | 06:50 AM
XR2's Avatar
XR2
Worn injectors, stuck warm-up regulator or something wrong with the metering unit.
First I'd check the fuel pressure.
Old Jan 14, 2012 | 08:35 PM
andmir's Avatar
andmir
Hi guys, I need help. I have some problems with my RS turbo engine. I have XR3 EFI convertion to OFAC. The engine starts but only 2 cylinders is warking. And I hear that fuel injectors are clicking. What s wrong?
Old Jan 14, 2012 | 08:42 PM
XR2's Avatar
XR2
Which cylinders?
Old Jan 15, 2012 | 01:14 PM
andmir's Avatar
andmir
Originally Posted by XR2
Which cylinders?
1st and 4th are working.
Old Jan 15, 2012 | 08:03 PM
XR2's Avatar
XR2
1. Twin coil
2. Twin coil connector (wiring loom)
3. signal wire for 2nd/3rd cylinder (wiring loom)
Old Jan 16, 2012 | 05:02 PM
andmir's Avatar
andmir
1. Twin coil
Thanks for answer. I will check out. It seems to be true
Old Jan 21, 2012 | 04:08 PM
XR2's Avatar
XR2
Problem sorted?
Old Jan 21, 2012 | 04:28 PM
andmir's Avatar
andmir
Problem sorted?
I will check it tomorrow.
Old Jan 22, 2012 | 04:03 PM
andmir's Avatar
andmir
Problem sorted?
I think that i found the problem. I have measured the impedence first at the twin coils and twin coil connectors. They are in working condition. Then I had done the same with coil connector which is located between fuel rail and ECU. I found that the brown/red wire (at the ECU pin 23 octane/idle adjust) has not impedence. It s broken. I will rewire it and try to start the engine. Today I had not much time for it. And it is cold in my garage.
Old Jan 22, 2012 | 04:14 PM
XR2's Avatar
XR2
I think that i found the problem. I have measured the impedence first at the twin coils and twin coil connectors. They are in working condition. Then I had done the same with coil connector which is located between fuel rail and ECU. I found that the brown/red wire (at the ECU pin 23) has not impedence. It s broken. I will rewire it and try to start the engine. Today I had not much time for it. And it is cold in my garage.
Cable broken or a problem with the ECU or the EDIS module
Old Jan 22, 2012 | 04:24 PM
andmir's Avatar
andmir
Yes broken wire (brown/red wire at the ECU pin 23 octane/idle adjust)
Old Mar 14, 2012 | 10:24 AM
andmir's Avatar
andmir
Problem sorted?
Hi. The problem was sorted. I had low impedance fuel injectors from sierra cosworth. I set my blue ones in and engine starts.
May be you know what MAP sensor I need if I have OFAC ECU? I know that I need V90FB9F479AA, but may be there is any MAP with the same characteristics it means analog?
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
