Injector question.
Old Sep 8, 2011 | 01:16 PM
clayton's Avatar
clayton
Default Injector question.
Currently have mondeo 2.0l beige side feed injectors.
What injectors do people upgrade these to to when they turbo these engines? They have to be side fed to fit the fuel rail.
Thanks
Old Sep 8, 2011 | 04:10 PM
clayton's Avatar
clayton
Any ideas?
Old Sep 8, 2011 | 04:19 PM
Icurus's Avatar
Icurus
Nissan SR20DET ones, like these http://www.ebay.co.uk/itm/Nissan-Sil...item5645a6ccad
But you would need higher flowing ones normally for a turbo
Old Sep 8, 2011 | 04:26 PM
paulhanzo83's Avatar
paulhanzo83
are the injecters you have beuge 701,s mate
Old Sep 8, 2011 | 08:04 PM
clayton's Avatar
clayton
Are the Nissan ones the same impendment? Not sure if they are 701s
These are the ones i currently have - Do you know what these flow?
Old Sep 8, 2011 | 08:39 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Std scoobypoo Impreza injector are side fed are they not?
Old Sep 8, 2011 | 08:47 PM
snoopaloopa's Avatar
snoopaloopa
Yes they are, as are the uprated ones from a phase 1/1.5
Old Sep 8, 2011 | 09:31 PM
Icurus's Avatar
Icurus
When we use them in the 16v RS2000's you have to swap the lower O ring with the one from the Ford injector, as the sizes are different.
Not had a problem with the impedance, though i'm running an Emerald ECU.
Old Sep 9, 2011 | 12:19 AM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Also interested to know this as i'm using the std rs1800 injectors (same as 2Ltr) fueling 160bhp at the moment and about to run low boost turbo approx 200bhp.
Was told when i had it mapped last there is loads left out of the injectors although i'm not so sure!!!
Whats the flow out of the 200sx and scooby injectors as i belive the 2Ltr ford side fed ones are approx 170cc/min?
Bri.
Old Sep 9, 2011 | 07:34 AM
clayton's Avatar
clayton
So are the Nissan/Scooby ones the same impedence as the fords?
Old Sep 9, 2011 | 07:53 AM
nevsrevs's Avatar
nevsrevs
You can buy a uprated ford side feed, called a f1, but these will not be as cheap as a set of second hand 1,s
Old Sep 9, 2011 | 11:07 AM
clayton's Avatar
clayton
the Nissan/Scooby ones will be fine if they are the same impendence as the mondeo beige injectors. Does anyone know?
Old Sep 9, 2011 | 11:21 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Nope they will be lows, but then you will not be able to use your ecu anyay so it wont matter
Old Sep 9, 2011 | 12:52 PM
massivewangers's Avatar
massivewangers
I know someone selling a brand new set of those, wants £200 for them I think
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
