Changing cams on cvh?
No! all cams exit from where the distributor is mounted, after removing all the lifters, pulley and cam shim that locks it in place behind the pulley on the left hand side.
valve stem oil seals and springs can also be changed with head on, with piston at TDC on whichever cylinder you're working on.
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
CrOwSoN15
Sep 14, 2015 11:33 AM
