Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Engine conversion help???
Old Sep 6, 2011 | 09:11 AM
hutch91's Avatar
hutch91
Default Engine conversion help???
Just wondering if anyone can help me i have a 1.8 focus but have a 2.0 engine sat in the garage would it go straight in or would anything need changing, iv heard a few different opinion on the subject just wondering if anyone done it know? Thanks
Old Sep 6, 2011 | 09:34 AM
Bailes1992's Avatar
Bailes1992
Engine is a straight swap, you need a 2.0 ECU or get your current ECU remapped.
Not sure if you could get a bluefin for a 2.0 model and upload it to your 1.8 ECU?
Old Sep 6, 2011 | 07:09 PM
hogdog's Avatar
hogdog
You don't need the 2.0 ECU, you just need to use the 1.8's injectors. The MAF sensor will detect the increased air flow and increase the fuelling to suit.
You'll also need the 1.8's flywheel and clutch so you can mate it to your gearbox.
Old Sep 7, 2011 | 08:49 AM
hutch91's Avatar
hutch91
I have the box for the 2.0 so that shouldnt be a prob, so all i need is 1.8 injectors in then itl run sweet? Have you done this before ?
Kyle Langford
27
Aug 5, 2019 07:54 PM
mint_s2
Sep 2, 2015 08:58 AM
