recaro 90 spec seats, cossie ecu, series 2 gearbox, zvh engine. + more
Just a few bits i have that i no longer need,
90 spec recaro seats, both front and rear bench, not sagged or ripped, there is on the head rest some small welding marks where the seats cant of been removed when some work was done at some point, but nothing major and you could always swap with a spare you have. Will not post due to size,
pics
some of the weld marks, hard to make out in the pics
Could do with a clean to bring them back up, wanting £100........SOLD
Cossie level 6 ecu with stage 3 chip fitted, i bought this for my zvh running cossie but never fitted it, no longer needed as going zetec with other management, As said i have never used this, was got from a trader on here abit back so have no reason to believe it wont work. looking for £110 posted.............SOLD
Also have a series 2 gearbox was in working order when removed no longer needed as going st170. collection only, £80
Mfi to Efi conversion plate £25 posted.....................SOLD
Cam sensor bracket and phase disk as used for efi/cossie conversion £40 posted
Cossie conversion bottom pully and trigger ring with alternator and belt to suit, unsure as to weight so will have to check postage, £50 + postage.
I have a 2.0 zvh engine with standard head fitted with piper cam, skimmed pistons, was built and done around 600 miles before removed due to rot on shell and will not be getting fitted in new shell due to going full zetec. would recommened a new cam be fitted as cam was showing some wear before removed but ran fine, better to mention it then not, engine does have a brand new set of lifters fitted but never got round to fitting cam so have done zero miles. i will get some pics up of the engine soon when i get some taken. looking for £400.
Pics
Sorry for the over sized pics but unsure how to make them smaller.
cheers adam
pics
Pics
cheers adam
Dont know anything else about the ecu or chip apart from what said, i got it from a trader off here in full working order, i assume its for l6 3 bar map and 803 greens, other then that mate nothing else sorry, i got it to do a zvh cossie conversion,
yes mate i have a cam sensor mount and phase disk, and bottom pully with 4 point trigger ring with alternator and belt to suit, just about to add them to the list.
cheers
Oct 9, 2015 07:38 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
