Grinding Noise
Old Aug 12, 2011 | 08:13 PM
simo2k2000's Avatar
simo2k2000
Default Grinding Noise
I've got a Mk3 Mondeo 2.0 petrol. When driving it sounds like there is a grinding scraping noise from the engine bay. It disappears when you depress the clutch.
To be honest the clutch slips if you give it some revs and try and make a quick getaway. Will the noise be something to do with this or will it be the gearbox or something?
Chris
Old Aug 12, 2011 | 09:41 PM
RichieST's Avatar
RichieST
clutch release bearing? I don't think the petrols have DMF's do they.
Old Aug 12, 2011 | 10:12 PM
simo2k2000's Avatar
simo2k2000
I don't think it has a DMF. Is the release bearing replaced if I send it in for a new clutch?
Old Aug 12, 2011 | 10:18 PM
RichieST's Avatar
RichieST
yes it should come with the clutch kit.
Old Aug 12, 2011 | 11:04 PM
LukeDaisley's Avatar
LukeDaisley
mk3 does have a DMF.
Old Aug 12, 2011 | 11:05 PM
simo2k2000's Avatar
simo2k2000
The petrol version? I thought it was just the diesel?
Old Aug 12, 2011 | 11:14 PM
simo2k2000's Avatar
simo2k2000
Just googled and yes you are right it has a DMF. It's not knocking and clunking so I think it's ok.
Probably the clutch release bearing. I'm just running it into the ground to be honest. I was given the car for free so I just service it every year and when it dies it dies. I am just curious what the noise was
Old Sep 25, 2011 | 04:29 PM
PeanuckleJive's Avatar
PeanuckleJive
If it helps at all, I had this very same scenario with my 2.0 tdci mondy, Just this weekend I put a new clutch and flywheel in and the noise has gone.
My thrust bearing and DMF were both shagged, so unfortunately I can't tell you which was causing the noise. But if you're going in there anyway, see if you can track down a DMF testing tool to see if it's bust. But to be honest you can sort of tell from the way it wobbles wether it's worth replacing.
Clutch, Flywheel and Thrust bearing for me set me back Ł520, not cheap!
Old Sep 25, 2011 | 04:32 PM
simo2k2000's Avatar
simo2k2000
The car's only worth 800 quid lol. If it needs replacing I'll just weigh it in or sell it I reckon
gingeRS
17
Oct 2, 2015 09:42 AM
20/20 vision
Sep 29, 2015 09:25 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
rsturbo27
Sep 5, 2015 05:08 PM
