cosworth engine parts gt30, shortblock, manifolds (fordfair prices)
Old Aug 1, 2011 | 05:25 PM
kaking1982's Avatar
kaking1982
Default cosworth engine parts gt30, shortblock, manifolds (fordfair prices)
gt3076r brand new garrett turbo never used it has .82 exhaust. compressor is 57mm inducor and 76.2 exducor,56mm trim and a 60mmturbine wheel 84mm trim good for 530bhp it is externally gated £720 Sold
200 short block rebuilt with wiseco 91.5mm piston with a 8.1:1 compression ratio. fitted to h section conrods with arp big end bolts . it has a new knifed edge crank bought from pj motorsport . burton power high flow oil pump and 2wd sump the block has been machined for mountune long studs which have been fitted and the block has been deck to take wrc head gasket. engine was built by myself as i build prototype ford engines . the short block cost me well over £3000 to build so a bargain at £1200
2wd ceramic coated exhaust manifold cost £220 to get coated £70
sweedish manifold unfinished needs fuel rail lugs welded on £60 Sold
2wd inlet manifold and throttle body finished in wrinkle black needs touching up £50
iskey double valve springs and titanium retainers and collets been fitted but never run £80
cosworth cam cover with breather pipe painted in wrinkle black with new bolts a few marks £30 SOLD
motorsport ht leads in good working condition £30
bailey swirl pot and blue silicon water hoses £20 SOLD
starter motor in new condition £15 SOLD
intercooler blue silicon pipes with dumop valve take off £20
fuel rail and regulator in wrinkle black £10 Sold
Old Aug 1, 2011 | 05:39 PM
AndyR1's Avatar
AndyR1
hello mate can i have the starter motor in new condition £15 and the bailey swirl pot and blue silicon water hoses £20 pm me how to pay ,cheers andy
Old Aug 1, 2011 | 05:55 PM
joffy's Avatar
joffy
SLOW LEARNER
how much for the cam cover posted please mate
Old Aug 1, 2011 | 09:34 PM
neo's Avatar
neo
i will take the swedish inlet manifold will you post it ??? pm me details etc...
If starter motor falls through i will take that too..
Fancy that turbo too if i can sort funds out
Old Aug 1, 2011 | 11:32 PM
lee2cossies's Avatar
lee2cossies
You have pm.
Old Aug 2, 2011 | 03:13 PM
R4N SS's Avatar
R4N SS
Are you going ford fair? If so bring the fuel rail and regulator please and will pay on collection
Old Aug 2, 2011 | 06:30 PM
Touring Car Spares's Avatar
Touring Car Spares
Are the threads ok in the Exh manifold , if theyre 100% then i may have a use for it , where in Kent are you ?
Old Aug 3, 2011 | 11:22 AM
kaking1982's Avatar
kaking1982
mid week bump
Old Aug 6, 2011 | 12:41 PM
kaking1982's Avatar
kaking1982
sat bump
Old Aug 6, 2011 | 02:40 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
hi i will have the inlet with the throttle body, pm me your payment details
Old Aug 6, 2011 | 03:09 PM
1300gt's Avatar
1300gt
I will take the exhaust manifold. Paypal ?
Old Aug 6, 2011 | 06:33 PM
1300gt's Avatar
1300gt
Cheers ollie will see you tomorrow
Old Aug 6, 2011 | 06:41 PM
RS500/364's Avatar
RS500/364
Very good prices if you at ford fair and want to put the other bits up on the auto jumble i got !
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
slammedorion
21
Aug 6, 2015 11:38 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
