ST170 Headlamp Washer Removal
Hi,
Anyone know how to remove the headlamp washer on a 2003 ST170? I've removed the jet sprayer from the front and taken out the headlamp unit. I've disconnected the water pipes but can't see how to get the jet assembly out. Basically it doesn't spray - the water supply is fine and the jet sprayer is clear - tested it (broke the rachet clip getting it out, so another reason to get a new one!), figure it must be that part that needs replacing....
Thanks
Thanks
cossie330
Oct 7, 2015 08:22 PM
Andypandy260
Sep 23, 2015 10:28 PM
Fudgey
Sep 17, 2015 01:06 PM
