Ford KA Discuss your Ford KA here!
Ford ka RST conversion
Old Jul 6, 2011 | 05:30 PM
thomasf's Avatar
thomasf
Default Ford ka RST conversion
Hi im looking to drop a fiesta rs turbo engine into my ka and then add the 195chip, t3 turbo, front mounted intercooler and some beige injectors...what bhp would i be looking to get from this and what changes should i make to my brakes and suspension.
thanks
Old Jul 6, 2011 | 07:24 PM
c123s1turbo's Avatar
c123s1turbo
think you answered your question already dude! 195hp
Old Jul 6, 2011 | 10:09 PM
thomasf's Avatar
thomasf
oh sweet thats sound then ...what brakes should i go for though, as i'm looking to convert the rear drums to discs...or would some bigger drums do the job?
Old Jul 7, 2011 | 03:56 PM
deano2690's Avatar
deano2690
leave the drums on the rear, if you change to disks (ST150 ect) then you are going to need a bias valve as well. As for the fronts, Mondeo v6 callipers and disks fit with slight modification iirc? slight drilling and tapping of the hubs to enlarge the holes is all I believe? and maybe some braided brake lines.
Old Jul 7, 2011 | 06:35 PM
thomasf's Avatar
thomasf
sweet, what shall I do about the drums then...get the same size ones that you have for the 1.6?
Old Jul 8, 2011 | 01:50 AM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
dont think about power before you sort the brakes and suspention, pumaspeed do a rear disc convertion but as far as i own its just a recon puma unit, 4x4 cossie brakes up front work well. go for braided line and up rated brake fluid as well. kw coilovers work well with the ka but are expensive so try avo or gas. the rst lump isnt a straight forward swap as a zetec, look for a second hand zvh lump if you still want a blower. a 130bhp zetec will give plenty of go in a little ka
Old Jul 8, 2011 | 02:06 AM
thomasf's Avatar
thomasf
sweet thanks mate, so many options to choose from lol...if i dropped a zetec blacktop engine in...what mods could i do to get it from 130bhp to around 160-170bhp?
Old Jul 8, 2011 | 02:40 AM
thomasf's Avatar
thomasf
and to add, which places sell the particular parts needed to mod...i.e cams etc
thanks!
Old Jul 8, 2011 | 05:05 PM
NoRubNoDub's Avatar
NoRubNoDub
full exhaust, good filter eg kn with a cold air feed and a set of newman or cat cams with a live map should see a good 160bhp with good troque. when it comes to tuneing zetecs theres only one place to go to, area 6
Old Jul 8, 2011 | 09:23 PM
thomasf's Avatar
thomasf
sweet thanks mate , i was gonna go for a set of cams, full exhaust with 4-2-1 manifold n high flow sports cat, uprated fuel pressure regulator n injectors n a live map
Old Jul 9, 2011 | 08:45 PM
Hobomassiv's Avatar
Hobomassiv
T3 turbo will not fit because of the Ka radiator.
There is a mount available for the RST and Zetec engines.
Old Jul 15, 2011 | 10:09 AM
zippyka80's Avatar
zippyka80
i was going to fit a 2.1 zetec turbo to my own ka but then i got married i still have the rad setup which is fitted to this car contact joey for all your conversion parts i also have st 170 front brake set up for a ka if you are intrested i have pm my number for you hope that all helps
http://www.trackdesigns.co.uk/
Old Jul 15, 2011 | 01:06 PM
thomasf's Avatar
thomasf
sweet thanks a lot mate , now im all confused about which engine to use...rst or 2.0 zetec....because someone mentioned on here that the t3 will not fit, but ive seen it on other KA's...is this with modifications?
Old Nov 25, 2011 | 12:10 PM
IceCage's Avatar
IceCage
Where is Joey?
Old Nov 25, 2011 | 12:11 PM
IceCage's Avatar
IceCage
Wink
Where is Joey?
Old Dec 3, 2011 | 07:13 AM
Hobomassiv's Avatar
Hobomassiv
I dont think Joey makes the engine mounts any more. I know of someone who makes them for around Ł150 delivered. PM if you need one.
With the standard ka radiator position the T3 WILL NOT FIT.
I actually own a t3 RST ka, and have a friend who built one using a T2 because the T3 wouldnt fit with the Ka radiator.
Old Dec 9, 2011 | 05:13 PM
rsmark86's Avatar
rsmark86
Just throttle bodies on a black top with a 421 manifold will see 170 bhp
Good luck p.s in a little ka I would want a screaming n/a engine to go with the fun chassis
Old Dec 9, 2011 | 05:16 PM
rsmark86's Avatar
rsmark86
Also just keep the t2 and have it built into t25 hybrid spec will do 200bhp and keep the punch
But I would go zetec
Old Jan 22, 2012 | 05:58 PM
thomasf's Avatar
thomasf
okay, well should I go down the zetec turbo route? or Just go for n/a? Im looking to make around 250bhp with equal torques
cheers
Old Mar 25, 2012 | 07:22 PM
CR41G_86's Avatar
CR41G_86
1.8 zetec ka in the makin
fiesta zetec s rear axel bolts straight on to the ka which would then allow st170 rear disc set up to directly bolt to the zetec s back axel.
fiesta zetec s axel is longer than the ka standard unit and would make the rear stance of the car wider ( not sure weather it would fit with standard arches or weather you need to fit euro arches or sport arches so the wheels dont stick out)
Old Mar 26, 2012 | 12:23 PM
Gary_Hurn's Avatar
Gary_Hurn
focus rear stub axels bolt up to a ka rear beam no need to chnage
Billy_RS
16
Oct 11, 2025 09:41 PM
Chas
Sep 21, 2015 08:57 PM
borboyous
Aug 22, 2015 11:17 AM
dlwarrior
Aug 5, 2015 10:19 AM
