i hav 2 problems! plz help!
Old Feb 11, 2005 | 03:01 PM
sufsRS's Avatar
sufsRS
Default i hav 2 problems! plz help!
gt a 91 s2, my tachometer always reads 2 high its dfntly mfi clocks it shows the rite speed at idle and when im drivin at say 4000rpm the tach goes off the clock!!!!!!?????
secondly, my temp gauge doesnt read it just stays at the top! it starts at the bottom then just goes above the red and stays dfntly nt overheatin as its bin like this ages HELP!!! cheeRS
Old Feb 12, 2005 | 06:06 PM
sufsRS's Avatar
sufsRS
Old Feb 12, 2005 | 06:13 PM
Graceland's Avatar
Graceland
Team HOTHOT!
sounds like someone has put the wrong clockset in at somepoint
Old Feb 12, 2005 | 06:25 PM
RS babe's Avatar
RS babe
Has it still got the standard dials or have they been replaced at some point? If they have been changed then it would seem that the needles have not been placed correctly...can be a real bastard to sort out, but not the end of the world...
Old Feb 12, 2005 | 06:29 PM
adamS2RST's Avatar
adamS2RST
Does this happen as soon as you put the ignition on? it shoots to the top? Think ur temp sensor is knackered, the rubber boots that push onto the head always fooke up and melt away after x amount of years. Sounds like the connection is not making proper contact.
Old Feb 13, 2005 | 08:45 PM
sufsRS's Avatar
sufsRS
nt possible as my dad was the previous owner of the car frm new, it is totally original sumfing has dfntly gne wrong
Old Feb 13, 2005 | 08:47 PM
sufsRS's Avatar
sufsRS
adam that is right it shoots up, i shal check this out, do u just get the new part from ford is it stil available cheeRS!
Old Feb 13, 2005 | 08:55 PM
Alvyn's Avatar
Alvyn
temp gauge is you need a new SENDER unit it's located in the head(can get it from Fords or any car acces shop) rev counter could be up the creek try get hold of another set to try!
Old Feb 13, 2005 | 09:08 PM
sufsRS's Avatar
sufsRS
my fault shud hav giv u full info: i tried my clocks from my other turbo which work fully and stil d same the rev counters the most weird it shows idling at 1100 then when i accelerate it movel triple the distance its meant 2 and goes off the clock on to the speedo!!!!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
